Pistons for ls3 heads
Old Oct 24, 2011 | 12:45 AM
1badeagle's Avatar
Default Pistons for ls3 heads
Im looking for a set of pistons and rods for my lq4 build. It's a 2004 6.0 iron block. I need pistons that have fly cuts for ls3 heads. I would like pistons that are .030 or so over stock bore. The motor will see nitrous occasionally. Thanks for the help.
Old Oct 24, 2011 | 12:26 PM
KCS's Avatar
KCS
Moderator
Check out Wiseco's pistons. They use a "multi-fit" valve relief which will fit the LS3 cylinder heads.
Old Oct 24, 2011 | 06:08 PM
1badeagle's Avatar
http://www.summitracing.com/parts/MLE-L92314030F04/
I actually found the set I was looking for. Does anyone know what kind of nitrous these pistons will hold with proper tune? I only plan on 100-150 shot.
Im going to be using a stock crank. Any recommendation on a good set of fair priced rods for my 370 build?
