Cam install problem: Crank pulley removal - M6x120mm bolts don't exist!
Ive done it with the stock bolt. Not easy, and not a great idea...but you can make it work. However...you are more patient than I and having one overnighted was a great idea. Good luck on the rest of your install
This is a good thread, thanks for all of the great ideas.
One question though, the last time I installed my pulley I could feel that the threads in the crankshaft were getting kind of funky, if you know what I mean.
Can you run a tap in the crankshaft without tearing up the tap, I just figured that the material in the crank was too hard?
All crank pullies that I have pulled off other motors had a "Woodruff Key" in the crank snout. They came off and re-installed easily. I have not looked at my LS1 but if it does not have a "keyed" crank; it is some kind of GM design screw up. If it is "keyed" then grind/hone out the pulley a small amount so it would fit easily. That is what I would do.
I don't think a GM design screw up is very accurate! There is no need for a keyed crank on a stock LS1 because of how the ignition is managed. (No timing marks on balancer etc...)
The only time a key becomes necessary for an LS1 is during supercharging applications where much more stress is put on the crank pulley...
Tommy
Tommy
Just ordered mine from mcmaster.com
Material Alloy Steel
Material Type Class 10.9 Blue-Coated Alloy Steel
Head Style Standard Hex
System of Measurement Metric
Thread Size M16
Length 120 mm
Thread Style Standard Right Handed
Thread Length Partially Threaded
Pitch (Metric) 2 mm
Specifications Met DIN 931
Cost $2.71 + around $3.00 for shipping
Thread Size M16
Length 120 mm
Pitch (Metric) 2 mm
