eps cam
my current set up is callaway c4b ls1 5.7 kinsler 8 throttle intake 50mm
1 3/4 headers
i was looking at replaceing the cam and was thinking about the
eps 234/246 cam with matching springs/rod/retainers
any thoughts would be good
Valve train is also less noisy. I highly recommend you call Geoff at EPS and tell him your goals and setup and let him spec you a custom cam.
If you email he should call you pretty quick, same if you call and he doesn't answer right away. Very nice guy.
I'm sure other times he might not be able to order and get one ground so quick but I was impressed.
If I would do it over, I would probably go a couple steps smaller so it wouldn't have to be wound up so high to make full use of its powerband.
What kind of 60 ft times, and what is race weight?
