ls7 vs LS1 lifters
Are the LS7's much better or just a replacement for our aging lifters?
Will they stand up to these springs:
1.550" dual springs
Spring Specs: 1.550": 200 lbs. @ 1.900", 480 lbs. @ 1.200", coil bind @ 1.150", max lift @ .700"
I have a 610 lift cam so Im not near the 700 max lift.
Thanks!
thanks!
Lift. .595 int .608 exh
Lobe Sep 115.0
That's the cam. I don't know how to determine the lift at the spring. Is it just my lift in the cam multiplied by the rocker ratio? Or is the .608 exh lift already taking into account a ratio? I assume there is some conversion done least as the springs can only do .700 lift.
As far as the springs, they are what came withy the heads I bought here on tech. And looking at springs on different vendor sites they aren't anything crazy. Stiffer then the 918's but about the same as the higher end ones they sell. I hope I don't new those f'n motels. I hate how everything spirals outta control.
Thanks for the help!
Lobe Sep 115.0
IN = 0.598/1.7 = 0.352"
EX = 0.608/1.7 = 0.358"
