Weird issue after head install?
Old Oct 31, 2011 | 11:41 AM
CamaroSS27's Avatar
Default Weird issue after head install?
I just recently installed heads and replaced my IAC because the old one I was lead to believe was bad because my idle would pulse up and down until the motor was warm. But now the car will start and turn off or barley start then rpm pulse and it dies. I unplug the IAC and it will start perfect. Sometimes after driving for a bit and I go to neutral sometimes it will idle at 1800 rpm for about 10-20 seconds then rpm pulse or just goto normal idle? Everything kinda happens randomly could this be needing a new tune or my IAC? I ask because I went from 241 heads to 243, I already had it tuned awhile back with bolt ons and cam.
Old Oct 31, 2011 | 11:51 AM
sman's Avatar
Id say it needs a tune.
Old Oct 31, 2011 | 03:51 PM
Rikoshay's Avatar
I had heard something about somebody who had installed the IAC backwards and it caused an issue like that. Maybe I'm thinking of something else.
Something to check anyway.
Old Nov 1, 2011 | 02:29 PM
CamaroSS27's Avatar
Ya I am pretty sure its on the right way. Thanks for the suggestion.
Old Nov 1, 2011 | 07:11 PM
SOMbitch's Avatar
I would post this in the tuning section because I think it could be a tuning issue...
Old Nov 4, 2011 | 04:41 PM
CamaroSS27's Avatar
^tried not one reply?
Old Nov 4, 2011 | 05:06 PM
3rdCoastPowerSports's Avatar
when you say RPM "pulse" do you mean its searching for idle? or is it more like the idle is hanging?
Old Nov 4, 2011 | 05:10 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
if you only switched heads, nothing else, and it did not do this before the swap, I would bet against it being tune related. Are you sure you got the grounds that tighten down to the back side of your driver's side head are secured, clean, etc?
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
