4.8 and LS1 stock cams question...
Cam Motion has their own 212/218 on 113* + 4* that is supposed to perform just as well or maybe even better, but there were more write ups on the Comp (which was about $50 cheaper) so I got the Comp. Either one will use the yellow '02-'04 Z06 valve springs.
Tuning will be required with either of these but you should be able to get a mail order tune from Frost or Black Bear no problem since this is such a popular cam design.
The +2 just means that it has two degrees of timing ground into the cam. So that was you can line it up straight up (dot to dot) And the cam timing will happen just as the manufacture intended without having to have an adjust timing chain set.
That cam is small it shouldn't have much if any lope to it, but smaller motors make small cams sound bigger than they are.
The +2 means there is 2* of advance ground into the cam, which will make power lower in the RPM range. The split duration that favors the exhaust is very common on an LS motor N/A cam, they all seem to make the best power using an exhaust biased cam.
I believe you can can reuse your stock push rods but I would always measure. I had to pull the heads to drill broken exhaust bolts so they got milled 0.025" to up the SCR to about 9.87:1, changing the length of my push rod's.
You will need a timing cover gasket, balancer seal, v/cover gaskets, oil pump (good insurance), LS2 timing chain (much stronger and doesn't stretch as much), and 5/16" wooden dowel rod's (to keep the lifters from falling down), and of course the GM LS6 valve springs. You are probably looking at $550.00 total in parts (including the cam).
I would also get L/T's as well, they have a nice set of SS L/T's for about $330.00 from one vendor. Go up to the "Performance Trucks" tab in the top left hand corner of the LS1-Tech home page and look in the GM performance section, there was a thread about these headers there.
