needfacts! 5.3 to 5.7
i have a 5.3 out of a 06 tahoe from wat i was told according to oter forums and articals it is possable to bore a 5.3 to 5.7 then agin i find a same amount of info to not do tht soo if some one could plz show me some solid facts with pictures of 5.3 bored to 5.7 success build thread or somethin or some one who has don this recently ad has no problems this is all i need to no as of now thks
http://www.youtube.com/watch?v=J_PyxsR73ug
My point is that unless the tune or heads mismatched etc in a 5.3l bored to a 5.7l the 5.7l would have to essentially make more HP than the 5.3L!
No replacement for displacement.
*NOTE* the HP ratings are in a different RPM range. That is why usually it is useless data to compare 2 engine's HP rating since it is basically comparing apples to oranges. You have to take into account what RPM you will be operating in, especially for towing applications. Who wants a 350HP engine putting out 350hp at 4000+RPM to tow with?
Instead of rebuilding the 5.3L, the added cost of boring to the 5.7l would be new pistons/rings (assuming the 5.3L didnt need them anyway), machine work and decent set of heads. (799,243 or aftermarket). Evrything else involved you would do with rebuilding the 5.3l anway. IE: gaskets, bearings, cam, etc.
BTW I have one of my salvage yard 5.3L's in the garage tore down and will be built over the winter to go in my 85 vette. The other 5.3l will get the 5.7l treatment also and eventually end up in my Sierra.
If you got the money to blow, sure go get a 6.0L or whatever floats your boat....but those 5.3l's are a dime a dozen and can be had all over the U.S. Im going to pick up another one or 2 to stash in the garage. My riding mower may need repowered sometime down the road. ha
Note: it may be more cost effective to start with a bare 6.0 block. The cost to bore the 5.3 out can get expensive.
