5.3/T56 in my swap. What cam?
I am doing an aluminum LM4 5.3/T56 swap into my super light Nissan. RTR curb weight should be right around 2400lbs.
Now, where the issue comes in is that the car is a super sleeper, so it has to retain a decent idle. I intend to run a set of ported 5.3 truck heads as well as a set of mid length headers breathing through the quietest exhaust I can find.
I emailed comp cams with my setup and needs and never had a reply. Through some searching I found that a TSP 224 sounds like it might fit my build, does anybody have any other suggestions? I don't need low end torque so much as high end power. The car will be a summer toy/track car, not a DD.
LS6 cam is a popular choice in a 5.3. I don't recall the exact numbers, but, guys are making a good 300+ RWHP with this set up. Check dyno section for results. There are dyno sheets for many 5.3/cam choice set ups there.
LS1Tech Premium Sponsor
The 224R would work great!
Although, we could probably spec you something a little more custom to perform better and meet your goals. If you are interested, please feel free to give us a call, we can get it narrowed down with a few more specifics.
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
Jake, I will do just that once I get further along down the line on my swap. There are a few things I'm waiting on that might be changed if they don't work out. Thanks for the advice so far guys!
