knocking sound that comes and goes?
Old Nov 7, 2011 | 07:39 AM
JACE323's Avatar
Default knocking sound that comes and goes?
What would cause a top end knock to come and go? If you let the car sit for an hour or so it will go away. I can only think its a lifter the is bleeding down and pumping back up?
Old Nov 7, 2011 | 02:14 PM
JACE323's Avatar
Has anyone had any problems with the oil pump o ring in pre-2000 cars? i see there is a TSB from GM for the newer motors.
Old Nov 8, 2011 | 03:41 PM
JACE323's Avatar
No one has even a stupid thought?
Old Nov 8, 2011 | 08:02 PM
joecar's Avatar
Too much lifter preload;
Not enough lifter preload;
(i.e. pushrods are not the right length).
Old Nov 9, 2011 | 01:46 PM
95_ls's Avatar
could b a worn out valve spring causing the valve to float and messing up you preload dont always blame the lifter right away, do you notice a drop off in power at certain rpms
Old Nov 9, 2011 | 04:03 PM
JACE323's Avatar
It is a stock engine so I assume the pushrods are the correct length. I havent noticed any loss of power but i have been babying it lately out of worry.
Old Nov 9, 2011 | 04:27 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Does it make more or less noise when the engine is at full operating temp vs when it is cold?
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Nov 9, 2011 | 05:48 PM
JACE323's Avatar
It will knock for a second when it first starts then goes away and stays quite untill it does this. It has only started when the eingine is at full temp and I havd been driving for a little while.
I have shut it down for an hour and come back to start it after an hour at the earliest, It will knock for a couple seconds then go away.
It has done it twice just driving around town for 30 mins or so. Shut it down for an hour restart and no noise
Then at the end of my hour and a half drive to milwaukee it was real bad. Parked it, went to my concert, came back out after a few hours expecting to have to call a tow truck and it didnt make a sound and was fine the entire drive back.
The only other thing I have noticed is the oil pressure seems to jump around quite a bit wether the engine is cold or warm. But it has never dropped below 30 psi.
Old Nov 9, 2011 | 07:32 PM
JRENIGAR's Avatar
Does it sound almost like a rod knocking or just a slight lifter ticking sound?
Old Nov 9, 2011 | 07:56 PM
lstransam's Avatar
its probally nothin your just letting it get to you man
Old Nov 10, 2011 | 12:06 PM
JACE323's Avatar
It sounds more like a loud rod knock but its faster like its valve train. Its not nothing I thought the motor was about ready to say adios the first time I hear it. It is VERY LOUD
Old Nov 10, 2011 | 12:20 PM
Reed35's Avatar
I was going to say lifter preload. but if it's a loud sound and still a stock engine. Could be "piston slap" I read somewhere that pre 2000 cars had that issue. Just an idea. How many miles are on it?
Old Nov 10, 2011 | 02:33 PM
white01ss's Avatar
If the sound seems to come out the exhaust pipes as well it probably just lifter noise as others have said.
What weight oil you running? Mine used to do this a lot when I was running 5-30 Royal Purple. Try running a thicker weight oil and see if it goes away.
Old Nov 20, 2011 | 03:56 AM
BigBadVoodoo Daddy's Avatar
Default Thoughts
Not to hijack ur thread but my car is doing the same thing, the knock comes and goes.....it seems like its on the driver side back by the exhaust....if it is lifter noise how do I get it to stop?
Old Nov 20, 2011 | 12:47 PM
LS1121's Avatar
water pumps will make a knock also.
Old Nov 20, 2011 | 12:58 PM
andrewss's Avatar
Carbon breaking off in the heads & pistons can make some loud knocking noises. Did you use any inj cleaning products lately?
