supporting mods for 243 heads and xer281
what are the best cheap pushrods? texas speed anygood?
what are the best cheap valvesprings i can get away with?
hate to keep saying cheap but im trying to do all this for as little coin as possible.
i know i need a timing chain,should i go ahead and get the gears too or do i need them?
oil pump-ls6 or ported ls6?
ls6 oil pump
ls2 chain only
pushrods
I am running the Patriot Gold springs ($250 new IIRC)
Don't forget head gaskets, water pump gaskets, head bolts (stock are torque to yield and cannot be reused), crank pulley bolt, oil, filter, and I'm sure I'm forgetting some odds and ends.
I would also have some new lifters on hand. Never know if one could be damaged and if the engine is high mileage they should be replaced anyway.
Really want to know if beehives will be good enough for the touquer v2 equalivant cam.Also what stall do i need 3200-3400? 3:23 rear and its just a street car-weekend bruiser
wheres the best place to get the ls6 oil pump?
ls6 oil pump
ls2 chain only
pushrods
We offer a ported and shimmed ls6 pump (approx. 10%better flow, and 10psi increase across the entire rpm range)
With the Torquer v2 we recommend at least a 3200 converter, in my car I would run a 3600...
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
The Torquer v2 is right at the limits of the pac 1218/comp 918s, but the pac beehive 1518s would work.
Is there any real difference between a torquer v2 compared to a v3? I was looking into get on of these cams.
Torquer V2 232/234 .595"/.598" 112LSA
Torquer V3 231/234 .643"/.598" 111LSA
The difference is we used a more aggressive intake lobe with a tighter lobe separation with the V3 to allow for better midrange over the V2.
Personally, on my car, I would run the PRC .650" Dual Springs with either of those cams just for my own peace of mind.
A friend used to have the v2 in his Trans Am and it was pretty wicked. TSP could probably make you a killer deal on everything you need.
Should i mill the heads any?
So far parts aquired are pac 1518 springs and 243 heads(gto)
tourker v2 or xer281 however you wanna look at it.
still need opinions on timing chain and oil pump.
Ive seen the ls2 slack,that cant be good,and there is the irws chain,i dont wanna spend over 50 bones so whats the best chain?
also oil pump,should i get a stock replacment or just rebuild mine?160k but oil pressure is great 40 idle -60 running
Definitely shave the heads, even a little bit helps. Mine were cut .010". If you have cam clearance, I would consider .020".
I am using the ls2 chain. I got a Lingenfelter ported ls6 pump pretty cheap, but like I said I bet TSP would make you a package deal for everything you need that can't be picked up locally.
I would expect a v3 car with full bolt ons, good tune, manual trans, and stock drivetrain with stock 243s to make ~415rwhp. Might squeeze a little more out of its all setup perfect.
