Double Roller Timing Sets In LS1
Old Nov 15, 2011 | 08:24 PM
Sales1@Texas-speed's Avatar
Originally Posted by 00pooterSS
What's your recommendation for strength, reliability and value? Do you rec the C5R or feel it is a bit overkill?
Not trying to thread hijack but all the C5R talk made me curious of the above.
The C5R chain is a great choice and super reliable piece. I also recommend the Nmotion single and double roller timing sets for the nice price and the fact that Ive used both chains in some very aggressive setups without any issues.
Old Nov 15, 2011 | 10:48 PM
95ONE's Avatar
Originally Posted by GNIUS
Where did you get your parts?
I got the double roller adjustable from TSP. I got the chain guide from GTP.Craig Gallant in Houston.
Old Nov 16, 2011 | 11:12 PM
CutLS's Avatar
Would you recommend a Double Roller for an engine that will be on and off the throttle alot? That is a real good price on that nMothion Double Roller. Does the nMothion have clearance and tube alignment issue?
Old Nov 16, 2011 | 11:17 PM
95ONE's Avatar
I think the C5R should hold just fine with a guard like mine. I went double because I wanted the adjustment and security of a tough chain. Alignment issues I won't ever know. I'm going 4 stage dry sump. Some front cover grinding is required. it comes with spacers for the oil pump though, which I would then be suspect of alignment issues with the pickup tube. Seems pretty easily corrected though.
