Low end torque camshaft opinion
I think you may want something closer to what you have now on a tighter LSA. I wouldn't jump down to low 200's duration. Although duration does affect wher eyou make power somewhat, all the specs combined create the power curve. The LS6 cam is a 204* intake duration, but it isn't like you couldn't do similar things with more duration.
And how low can you really use on the street? Is your car a manual or an auto?
And why haven't you considered some long tubes?
A lot of the so called "torque" cams, or "truck" cams as they also masquerade as, are in the mid to high 2-teens, which is I suppose where you are talking about (thought you mean like real low 200's earlier). The only caveat I would consider is going wider on the exhaust split due to the stock manifolds, the only problem being as EVO gets earlier it will bleed off torque. I guess the power / torque balance is in question. Most stock manifold cams will have a lot of exhaust duration, which helps with the power. Like this one.
Yes I think on a tighter LSA the trutorq would feel punchier in the middle. Maybe call TR and ask what they would think about it. The 216/220 might not be bad either. EPS has the 218/222 that the name escapes me... that or maybe even 218/226 on a narrowish LSA. Comp also has one on LSL lobes that is 215/223 .604/.610 112LSA 107ICL that would probably also work. There is a nitrous cam from Cam Motion 216/228 .561/.561 LSA 114 ICL 110 that might be interesting.
To be clear about LSA though, it doesn't exactly shift the torque lower, it typically builds it faster and to a higher peak, and it falls off faster. The intake, and to a smaller extent exhaust, duration are going to have a bigger role in determining what RPM the torque peak is at. Advancing the cam, which opens the intake valve earlier and closes it earlier, will shift it a little lower... part of the reason most of the shelf grinds have default advance in them.
Your desired lift is going to start narrowing it down. There are some lobes with decent lift that are supposedly quiet like the EPS lobes and Comp's LXL lobes. I'm running out of the amateurish advice I can give, so you might be at the point where talking to a sponsor is the way to go.
If you didn't have a cam and asked for a decent torque cam, something sort of similar to 218/226 LSA111 might be a good rec. It would still have 0 degrees overlap at .050" so it would probably not be too hard to live with. That's sort of like the EPS "Truck Torque 2" but the shelf grind is on a 115 I think. But something in the same ballpark from whichever vendor you like I would otherwise think would work out. Unfortunately it sounds somewhat similar to what you have right now. I don't really know how much of an improvement you could make dropping the intake duration and the lift. Sort of why I thought maybe narrowing the duration would help it "feel" a little bit better in the mid range. Who knows, maybe something like Cam Motion's 212/218 .561/.561 LSA112 ICL108 would be to your liking. :shrug:
W/LT headers:
215(.604" w/lsl) intake, and 222(.602" w/lxl) exhaust, 111-112 lsa w/3* to 4* advance.
W/stock manifolds:
215(.604" w/lsl) intake, and 226(.605" w/lxl) exhaust, 111-112 lsa w/3* to 4* advance.
I would also consider contacting Geoff at EPS, Pat G, and PredatorZ, and see what they recommend.
FYI, You can get the ceramic coated BBK LT hdrs and ORY-pipe for about $500, they fit great, and you won't lose any ground clearance with them!
At least there is something out there. I try to collect some of this stuff and put it in the VE / Cam spreadsheet to easily compare them.
At any rate, back to the topic at hand I suppose.
We offer the LXL and many other lobe families on our custom grind cams
It lists the duration @.050" and valve lift with a 1.7:1 rocker ratio inside that link.
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Vehicle:
2001 Chevrolet Camaro SS, M6
Engine Modifications:
Intake Lid
AIR system deleted
Descreened MAF
25% Underdrive pulley
160° Thermostat
Camshaft: Comp Cams LSL lobes, 215/227 115 LSA +2 advance
Cylinder heads: Stock unmilled 243 heads, 1.7 ratio rockers
Head gaskets: .040” Cometic
DCR estimate: 8.65:1
Exhaust Modifications:
3” I-pipe with single 3” Borla XR1 high-flow muffler, single 3.5” exit ("1 out the left"), stock 2001 exhaust manifolds, cats & Y-pipe
Dynojet SAE:
Doing this in my head more or less bc I don't have my sheet that does it for me on my laptop
219/224 .604/.609 115LSA -> -8.5* overlap @ .050" The TrueTorq. There is still some wiggle room to narrow it, but probably dropping the intake duration to get earlier IVC is probably a little better. 113LSA would be -4.5.
215/223 .604/.610 112LSA 107ICL -> -5* overlap @ .050"
216/228 .561/.561 114LSA 110ICL -> -6* overlap @ .050"
212/218 .561/.561 112LSA 108ICL -> -9* overlap @ .050"
218/226 .595/.598 113LSA -> -4* overlap @ .050"
214/226 .600/.595 113LSA -> -6* overlap @ .050"
I posted those first three above previous posts. The next is the actual specs of the EPS Truck Torque 2, the last is the intake from the Truck Torque 1 with the exhaust of the Truck Torque 2. I don't know IVC's offhand.
When I installed my ported fast 85 I noticed right away that throttle response and torque improved everywhere, even down low around 2000 rpm. I made 365 rwtq @ 3000 rpm and 400 rwtq @ 3800 which I felt was really good numbers for what I had. If I remember correctly I gained 33 rwhp / 25 ftlbs over my LS6 intake.
Found my graph, its bolt ons vs head cam ls6 intake vs head cam fast + underdrive
