reluctor wheels for silverado!
So I work at a remanf. engine company and we have a 5.3 listed for 99-07 silverados and what not. I was tell them how do we know about the reluctor wheel and which one is which. They are saying they will work from those time frames. I am just trying to help out as much as possible here at work, but can you correct me if i am wrong please. From my understanding up till 04 they had the 24x wheel and anything over that is 58x. also they are not interchangeable due to the sensor and of course the wheel being different.
Am I wrong here?
Any help is greatly appreciated!
Thanks!
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
we have them listed that any 99-07 silverados are all the same aswell as reluctor wheels
If so, can the 58x work on the 24x with out any changes? and vice versa?
The full size trucks switched from Gen III engines to Gen IV engines when they made the switch to the 58x wheel and the new ECMs. In some of the other vehicles GM confused things a bit by switching to the Gen IV engine but staying with the 24x reluctor wheel for a year or two. So, for example, the 2005 Corvette has the Gen IV V8 LS2 engine but is 24x wheel (E40 ECM). The 2005-2006 GTO and SSR are also Gen IV V8 LS2 with the 24x wheel but the 2006 Corvette has the LS2 engine with a 58x wheel. So even for the same model year and engine designation, not all engines have the same reluctor tooth count or ECM type. This confusion is one of the reasons we ended up producing our 58x to 24x conversion module.
The instructions for our conversion module (that someone else already mentioned) has a fairly complete table of what vehicles/years use which reluctor wheel and camshaft wheel along with pictures of the different parts to help identify them. The instructions can be downloaded here (go to pages 12 and 13 for the table of vehicles):
http://www.lingenfelter.com/sites/li...ons%20v1.5.pdf
If you have the VIN from the customer vehicle it is pretty easy to confirm which controller and reluctor wheel they need based on the engine family code and the calibration files. If the customer has the original engine it is pretty easy to tell from the crankshaft sensor color as well (see the instructions linked to above for pictures etc.).
2007 was a transition year but I don't know if they continued to stretch out the old trucks chassis for longer outside the US. I know on the previous chassis/vehicle transition year (1999) you could still get 5.7L Vortec Gen 1 V8 equipped trucks in Mexico and elsehwere for several years after they were no longer available in the US.
