rod bolt torque on arp 8740?
Right, with the cracked rods it seems like replacement without machine work is normal.... Hope so as I am planning this next week!
Are the aftermarket rods also a 'cracked' type?
SCAT H Beams with ARP 2000 => 50 ft lbs
SCAT H beams with ARP 8740 => 63 ft lbs
Also spoke with a mechanic at texas speed and got the torque specs for ARP main studs
Inner => 60 ft lbs
outer => 50 ft lbs
bolts out side of block => 20 ft lbs
Hope this helps someone in the future.
ARP Brand Moly is not mandatory, store bought can be used just make sure you go back through the motor and retorque to ensure it didn't relax.
Also, is that for the 3/8" bolts or 7/16"?
