melling 10295 clear a double roller chain?
Old Nov 18, 2011 | 01:36 AM
mondols1's Avatar
Default melling 10295 clear a double roller chain?
will the milling 10295 oil pump clear a double roller timing chain?
what sponser has the best price?
Old Nov 18, 2011 | 03:38 AM
01ssreda4's Avatar
Depends on what chain. If they wont clear then the chain maker should supply shims.
Old Nov 18, 2011 | 10:03 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Most double roller chain sets include shims to space the pump out. But still be aware it is not uncommon to need to clearance the backside of that pump and/or the front cover! It is the responsibility of the installer to do this check before start-up, regardless of what anybody on the web forums says!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
