can someone ID this timing setup please?
Old Nov 21, 2011 | 09:17 PM
PRAY HRD's Avatar
Default can someone ID this timing setup please?
just trying to figure out if its an ls2 or something else. i'm having a hard time seeing the dot on the bottom sprocket. thanks!
Old Nov 21, 2011 | 09:52 PM
PRAY HRD's Avatar
previous owner just texted me back and said its supposed to be an ls2 chain. do they not have a dot on the lower sprocket that you can see when installed or what? any help is greatly appreciated!
Old Nov 21, 2011 | 10:18 PM
dodson55's Avatar
it does not look like a factory ls2 mine did not have the holes in the top sprocket it is a ls2 style buy i believe it is some kind of aftermarket
Old Nov 21, 2011 | 10:20 PM
JS01's Avatar
that is a after market single roller set up for LS2 cam sensor. turn the motor to 1# TDC and you should be able to see where its installed at on the bottom gear. there will be numbers on the bottom gear not a dot.
Old Nov 22, 2011 | 06:02 AM
PRAY HRD's Avatar
thanks guys and good call JS01! that's exactly right, there ARE numbers on it! so what # should be showing at tdc for the #1?
secondly, is this a strong enough chain for about an 800rwhp+ turbo setup or am i gonna need something else?
