317 or ported 241's?
Basically I don't know if the higher CR of the 241s would offset the lower flow. And can I mill the 317s enough to get decent CR?
So i have a few options.
Run the 241 set, sell the 317 set.
Get the 317 heads cut to fit the 2.02/1.60 valves, swap valves and springs to the 317, sell the 241.
Run the 317s with stock valves and sell the 241s with the ss valves.
Opinions?
is better. If they're milled, then the dished LQ4 is probably up around 10.5compression now which is helping. The 317s would have to be milled alot to
get the compression. I'd stay 241s.
