408 stroker big cam surging at idle
Old Dec 3, 2011 | 06:23 PM
zblubyu's Avatar
Default 408 stroker big cam surging at idle
i just had a 408 stoker put in my zo6 and we did the fast 102 intake with the 92mm tb. this may just be a tuning issue but i cant get it to idle vary well. it wants to surge at idle. what might this be?
Old Dec 3, 2011 | 06:50 PM
DrkPhx's Avatar
More than likely a tune issue. Has it been tuned at all?
Old Dec 3, 2011 | 07:03 PM
zblubyu's Avatar
it has a break in tune on it. the lowest we could get it to idle is 1,100 rpm any lower it wouldnt idle without shutting off when letting of the throttle on a roll
Old Dec 3, 2011 | 07:32 PM
DrkPhx's Avatar
That's real high even for a big cam. The tune needs work. What size cam?
Old Dec 3, 2011 | 07:45 PM
98hc4mula's Avatar
That is pretty high idle, I got my 408 idling at 825 rpm with a 244/244/ .610 113+3 cam it drives so nice due to countless of hours tuning it. Have the tuner work on it some more. and some more.
Old Dec 8, 2011 | 07:54 PM
RyanSws6's Avatar
I've had tunning issues about idle. I've had several tunners TRY! It pisses me off to drive it sometimes. WOT is like sex but slowing down a PITA. I think its a throttle cracker issue, seems to run too rich. I've heard my 102 TB is too big..etc...I'm considering going SD. I just can't keep throwing money at tunners. I'm going to try a BIG rice tunner. We'll see. Oh I did check EVERYTHING for air leaks and re tq'd the intake.
I would tell you to check for air leaks.
Old Dec 8, 2011 | 08:17 PM
Sales1@Texas-speed's Avatar
Assuming that everything is installed correctly it definitely sounds like a little more time needs to be spent finalizing the tune.
Old Dec 10, 2011 | 03:10 AM
macca33's Avatar
Look at the Desired Airflow, Base Timing / Timing table, Commanded AFRs, etc, etc... It probably needs more idle airflow, at the very least.
cheers
