Stiffer springs in 243 heads with factory hollow stem valves?
Old 12-06-2011, 11:44 AM
DeaconBlue's Avatar
Default Stiffer springs in 243 heads with factory hollow stem valves?
The factory yellow springs have 90lbs seat pressure and are noted for 0.570" max lift. Are there any reliability issues with the factory hollow stem valves if you were to switch to say a stiffer spring such as the Comp 915 with a 105 lbs seat load and .600" max lift? I was thinking of setting up the engine with a fresh set of heads and either the GT2-3 cam (0.573"/0.578") or the factory '02-04 cam with 1.80 rockers (0.583"/0.579"). I am installing the Comp Ti retainers to help reduce the valve train mass as well.
TIA
Old 12-06-2011, 12:56 PM
ZeeOSix's Avatar
Lots of guys put stiffer springs in their LS6 (243) heads and have no issues with the valves. You should be fine with your plan.
If those heads are off a 2002 or 2003, I'd recommend getting rid of those OEM yellow springs anyway as they are known to fail.
Old 12-06-2011, 01:37 PM
DeaconBlue's Avatar
Okay I have a set of fresh Comp 918 springs with 125 lbs of seat pressure and I was thinking that those would be too much for the factory hollow stem valves (very thin 0.8mm walls). Since I am not going over 0.600" lift, I think I will just drop down to the 915 springs to be on the safe side.
Old 12-06-2011, 01:44 PM
HioSSilver's Avatar
Good post. I thinking of trying 1.8 rockers on my ls6 also. From what I seen it looks like it boosts midrange power pretty good.
Old 12-06-2011, 04:40 PM
kenp's Avatar
I run Comp 918s on my oem hollow stem & sodium filled valves. No issues.
Old 12-06-2011, 04:53 PM
SweetS10V8's Avatar
Ive seen 918s, with hollow stems run 8500rpm on the Spintron on a .620+ lift cam. Its a good combo, just add a set of pushrods.
Although thats with 1.7 stock rockers, aftermarket rockers are nose heavy and can cause valvetrain instability. Id stock with the stock rockers w/ the Comp trunion upgrade
Old 12-07-2011, 12:21 PM
DeaconBlue's Avatar
The 12564824 heads came in today - the last two new in the box '02-04 Z06 LS6 heads that were in the GMPP network. Date on the box is Jan '06. They are fitted with the LS2 orange 12586484 springs, not the earlier LS6 yellow 12565313 springs.
Old 12-07-2011, 03:49 PM
ZeeOSix's Avatar
You should be good then. I thought you might have been buying some used heads that had the original yellow LS6 springs. So you got the last two new LS6 heads in existence ... lucky .
Old 12-07-2011, 05:06 PM
sparkwirez06's Avatar
do the hollow stem valves have a longer valve stem?
Old 12-07-2011, 07:02 PM
DeaconBlue's Avatar
Yes the '02-04 hollow stem valves have a 0.6mm longer stem length to compensate for the smaller base circle of the '02-04 LS6 camshaft.
Old 12-07-2011, 07:04 PM
DeaconBlue's Avatar
Thanks - these may have been left over from CTS-V LS6 production run.
Old 12-07-2011, 07:39 PM
HioSSilver's Avatar
Whats the difference in the yellow vs the orange springs?
Old 12-07-2011, 09:09 PM
JPH
JPH's Avatar
The factory yellow springs have 90lbs seat pressure and are noted for 0.570" max lift. Are there any reliability issues with the factory hollow stem valves if you were to switch to say a stiffer spring such as the Comp 915 with a 105 lbs seat load and .600" max lift? I was thinking of setting up the engine with a fresh set of heads and either the GT2-3 cam (0.573"/0.578") or the factory '02-04 cam with 1.80 rockers (0.583"/0.589"). I am installing the Comp Ti retainers to help reduce the valve train mass as well.
TIA
I would suggest using a #PAC-1218 spring in this application. Valve control could be an issue with your 1.8s and lighter valvetrain by NOT using the correct seat/open spring pressures to control everything.
Old 12-07-2011, 09:19 PM
gectek's Avatar
Manley has a better pressure yet, but are a little more money. They have them rated to .600 and .650.
Pac or Manley are my bets.
Old 12-08-2011, 12:10 AM
LS1-450's Avatar
TIA
Stay away for the 1.8 rockers. They're mainly for guys who don't want to do a cam swap & want the benefit of a little better lift from their stock cams. Really aren't meant for higher lift longer duration after market cams.
8500 RPM...That's awesome. Did the engine use .105" wall pushrods, stock walled hardened pushrods, or other?
Old 12-08-2011, 01:16 PM
DeaconBlue's Avatar
Well that is sort of what I am looking for, the shorter duration and wide lube separation of the stock cams, but with more lift. Plus I would have to do the trunion upgrade to the stock rocker anyways. When I priced out my options the best deal for me was the '02-4 LS6 cam with the 1.80 rockers. I would have loved to do the GT2-3 cam with the trunion upgraded stock 1.70 rockers. The numbers are fairly close. Plus this engine is going into an older street car and I where live we have the chassis dyno emissions testing to deal with.
Old 12-08-2011, 01:20 PM
DeaconBlue's Avatar
Hmmm... Those PAC-1218 springs are interesting. The specs are very similar to the Comp Cam 915 spring, but with a much higher installed seat pressure that is closer to that of the Comp Cam 918 spring.
Old 12-08-2011, 01:30 PM
LS1-450's Avatar
OK, that works, LS6 Cam + 1.8 rockers. Just be sure to get centered valve wipe pattern from the proper pushrod length. Hate to see you not get everything out of the hollow stem valves though. They're really good for high RPM...larger cams that make power through higher RPM's.
Old 12-08-2011, 04:51 PM
ZeeOSix's Avatar
The pre-load on the PAC springs gives them the higher closed seat (installed height) force.
Old 12-08-2011, 05:06 PM
gectek's Avatar
If you are looking at numbers, then you would prob want to check your installed height then make your calculations from there. All those places have the lb per inch layed out afaik or at least a calculation for you to use.
Quick Reply: Stiffer springs in 243 heads with factory hollow stem valves?
