LS1 crank in an LS3 block?
Old Dec 7, 2011 | 10:40 AM
waterbug1999's Avatar
Default LS1 crank in an LS3 block?
Been 2 years since ive been down and starting to get some things together...
I got a good deal on a LS3 block so wondering if i can use my LS1 crank in it and just buy the forged rods and pistons?
Old Dec 7, 2011 | 11:04 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Yes sir, that will work! Make sure you balance the assembly, as always. Also, you'll need to run the LS2 timing set with the 1X cam reluctor so your PCM will run it properly.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Dec 7, 2011 | 11:08 AM
kinglt-1's Avatar
good info!
Old Dec 7, 2011 | 12:27 PM
U guys carry that?
Old Dec 7, 2011 | 01:08 PM
Yes sir, we stock the Rollmaster, N-Motion, and Comp Cams timing set you need!
__________________
Old Dec 7, 2011 | 01:11 PM
mercccc's Avatar
I'm in the process of doing the same exact thing...what pistons you going to use
Old Dec 7, 2011 | 02:08 PM
u wanna link it so i dont get the wrong one?
Old Dec 7, 2011 | 02:09 PM
Havent got that far yet... Im building mine for FI.
