out on a limb here
Old Dec 9, 2011 | 10:56 AM
optiplex's Avatar
Default out on a limb here
im going out on a limb here:
is/ would it be possible to make a 500whp on a stock bottom end LS1 N/A?
I have 241 heads that have had some decent port work done,5 angle valve job with 2.02/1.60 valves, comp cam (cant remember the specs, but its pretty big iirc) ported intake and all the bolt ons, and it made 475 to the wheels. Can i pick up 25 hp by balance and blue printing the Rotating Assy. and doing some more port work?
Old Dec 9, 2011 | 02:16 PM
optiplex's Avatar
Ttt...
Old Dec 9, 2011 | 02:22 PM
ljsracing19j's Avatar
Probably not. Atleast on the shortblock side of it. You could raise the compression a tad (assuming you arent pushing the limits as it is) and the porting it depends. It could help you or hurt you. Who is going to do it? Have they ever done it? Etc. To pick up 25hp will me somewhat hard but not undoable.
Old Dec 9, 2011 | 02:43 PM
optiplex's Avatar
ill be haveing BES racing engines do the motor and port work...
Old Dec 9, 2011 | 04:31 PM
86lxnotch's Avatar
lighten the rotating assembly up, lighten the valvetrain up, bump the comp a little if possible. maybe degree the cam to raise the powerband, if the portwork is good you might pickup up top a little. tahts off the top of my head. sure theres more you can do....it all adds up
Old Dec 9, 2011 | 04:50 PM
BigB02Z28's Avatar
Couldn't he switch to 243 heads with some port work and be there?
Old Dec 9, 2011 | 05:19 PM
black00ssFL's Avatar
I'll believe the 475hp with ported 241's when I see some track times. Sounds like a few more tweaks on that dyno and you'd be there without any mods.
Old Dec 12, 2011 | 12:05 PM
optiplex's Avatar
the car ran a (so far) best 12.07 @ 117mph with street tires and a stock trans.
the trans now is built with a 4400 stall, 3.73 gears
the heads have been milled .10 so i think my comp. is somewhere around 10.75:1
would it benifit to put some RR rockers? something like Harland Sharp OR?
Thanks Guys..
Old Dec 12, 2011 | 12:16 PM
djfury05's Avatar
Car is not making 475 to the wheels with 241s and an A4 sorry not happening.
Old Dec 12, 2011 | 12:38 PM
Fry_'s Avatar
sound's like the dyno was turned to the happy customer setting, and not the cold hard facts setting.
Old Dec 12, 2011 | 03:03 PM
optiplex's Avatar
two different dynos. Made 460, 472, then 475
second dyno: 473, 473, 475
Old Dec 12, 2011 | 03:31 PM
RonSSNova's Avatar
BES as in Tony Bischoff?
ron
Old Dec 12, 2011 | 03:57 PM
optiplex's Avatar
Yes Sir..
Old Dec 12, 2011 | 05:51 PM
djfury05's Avatar
I have 475 to the wheels and I trap 125+.. why you so slow with the same power??
Old Dec 12, 2011 | 06:17 PM
RonSSNova's Avatar
Yes Sir..
ron
Are you sure they can even keep it under 500hp?
Old Dec 12, 2011 | 09:32 PM
I trap 117mph with 400whp. You're not making 475whp to the wheels, unless that thing weighs 4500lbs. Keep the stock rockers.
Old Dec 13, 2011 | 09:38 AM
optiplex's Avatar
stock suspension, street tires, 2.3 60'
ill let him do what ever he wants to it
Old Dec 13, 2011 | 10:27 AM
djfury05's Avatar
stock suspension, street tires, 2.05 60 ft 11.79 125mph
Old Dec 13, 2011 | 02:56 PM
optiplex's Avatar
idk...track prep was ****, thats the only thing i can think of.
i might not have been clear in my previous post:
the 12.07 was when the car was pretty much stock. It had 3.73 gears, exhaust (no headers), lid, and a 100 shot. and with that combo it put down 415ish on a mustang dyno..
anyway, my intention with this tread wasnt to prove what my car has now, but to see if the magic 500RWHP is acheavible with a stock cube/stroke LS1.
djfury05, you have a very beautiful car.
Old Dec 13, 2011 | 03:20 PM
IRONFIST's Avatar
It's just really hard to tell you how to improve upon your horsepower number when none of us here know how you got there in the first place. You shouldn't be making that kind of power already...
