New Setup?
Now is the time to switch my setup. I am happy with the setup but the cam is rather large (see sig) and going slow is a pain in the but. The whole setup has about 15,000 miles on it.
I was thinking of changing the cam and and possibly a set of heads. I am not sure how much it costs to redo the 853 casting heads but it would probably be worth it to get some new heads, maybe some 243's? As for a cam I was thinking of going with a EPS cam custom specd, that way I get the cam I want instead of a off the shelf cam. The downside with the heads is I will need injectors and also a new tune for the heads and cam.
What do you guys think? I mean I could just pull it apart and use all the same parts with just new bearings in the motor.
It fired right up when I had everything back together.
I had 140,000 miles on the engine when I tore it apart so a lot had to be replced. I reccomend use your best judgement, if it looks less than par, replace it. Don't make the error of reusing a $50 part that is going to cost you your engine if it fails.
He said most likely the cam is still good, I doubt the heads need anywork or anything else. I just would hate to sink $500 into these junk 853 heads.
