Yet another pic a cam for me thread
Old Dec 10, 2011 | 07:34 PM
parks450's Avatar
Default Yet another pic a cam for me thread
A little background on my set-up:
Motor is in a 2003 4x4 s10
Motor is a 2004 5.3l Bored out to a ls1 bore (3.898)
All ls1 rotating assembly and COMP valve train
FAST 102 intake, I know its overkill for this but I got a awesome deal on it so i am going to use it until I build my 408 later down the road.
LS6 243 heads, lightweight valves and have the later casting with the triangles by the spark plug holes, virgin heads not cnc'ed or ported. I plan to keep these the way they are until later down the road but I can mill them to bump my compression a little. How much do you guys recommend milling them? Also what kind of head gaskets should i run? stock GM performance mls gaskets?
Trans is a built 4l60e with a 3000 stall
I'm looking for more mid to top end pull but not looking to sacrifice my torque down low.
Truck will mostly be a street truck with little track time, I had it going for 300 miles already but heads were 799's and a ls6 intake but I had to tear the motor down from internal problems so I would like to amp up a few things. I know the heads are close to the same but I got them for what I sold my 799's for so I figured what the hell right? I think that's it....Now lets hear some opinions!!!!
I have this cam now but it didn't impress me a whole lot.
http://www.summitracing.com/parts/CCA-54-412-11/
Street manners aren't that important, but I do not want to fly cut nor do I have the tools.
Old Dec 10, 2011 | 07:40 PM
1nasty86's Avatar
Turd Gen Guy
eps 226/234, this cam usually makes KILLER power for its size
Old Dec 10, 2011 | 08:57 PM
parks450's Avatar
What about the ms3? That seems like a popular cam, do you have to flycut with these?
Old Dec 10, 2011 | 09:03 PM
973800CamaroRS's Avatar
Why not a custom cam ?
Old Dec 10, 2011 | 10:12 PM
parks450's Avatar
Thats not out of the question. Ive heard of COMP's cams wearing lobes off. I have one of theirs seemed fine but only had 300 miles on it. Seems like a myth almost, anyone deal with futral or others?
Old Dec 11, 2011 | 01:17 AM
99Bluz28's Avatar
IMO, go with more aggressive/higher lift lobes and up the duration into the upper teens to low/mid 220's range.
EPS has the Truck Torque 2, or the LS 222/226:
http://www.engpwrsys.com/index.php?a...od&productId=5
http://www.engpwrsys.com/index.php?a...od&productId=8
or go with a custom cam grind.
Old Dec 11, 2011 | 07:56 AM
86lxnotch's Avatar
custom is always best but if your planning even bigger down the road and want a "hold me over" type cam then a off the shelf should workgood enough
im gonna call BS on this, it may have happened BUT 75% of the cams out there are ground by comp for other people and labeled as theirs. i had bennett racing do a custom stick for my 408w/101mm setup i had in my mustang and it came from comp. unless its direct from a cam company comp has alarge share of making them
Old Dec 11, 2011 | 09:26 AM
parks450's Avatar
Thats what I thought to about COMPS lobes. who are some good people to call. I know ed cutis, pat g, are awesome, so should I stick with them?
Old Dec 11, 2011 | 07:41 PM
parks450's Avatar
Bump anyone else
Old Dec 12, 2011 | 09:39 PM
parks450's Avatar
Nobody would like a few vendors to chime in if i could.
