combustion chamber question
If you have an "as cast" head and the only thing you change is polishing the combustion chamber you will have slightly less compression. This equals slightly less power which may be what this guy is seeing with the bbc rails. I believe you are correct...rough or sharp edges do encourage detonation (hot spots). I suppose if you are not running on the ragged edge of compression (vs octane) then leaving it rough will gain you some power/compression.
on pic is of intake ports one of the exhaust and other of the intake ports valve side.
hard to tell much from the pics though
i guess ill leave them ruff....
I spent nearly 7 hours each on my 799s doing such smoothing after the carbide work was done.
I'm doubting those are actually as rough as they appear in the photos. Could always go over them again with a few cartridges of 80grit.
I'm definitely no expert either, but I just got done going over my 317's myself. I was actually going to ask about the rocker bolt hump, that's why I asked for more angles.... still hard to tell in the photos exactly how much they were taken down, but I don't think I went quite that far. Mine are still visible when you look perfectly straight into the port opening. Not sure if I should knock them down more or not?
I also left much more of that ramp that was next to the intake valve guide too, compared to those.
And I did not open up my exhaust port exits into a big full circle like that. Those look like he basically gasket matched them...? I opened mine up a decent amount, but kept the “D“ shape, but now wondering if I should have just opened them up to size of gasket...?
oh, and did I miss it, which head castings are those?
