Trick Flow Heads/cam kit
Those are about the numbers I'm after, does it still have street manners?
i added a fast 92mm intake and some 42lb injectors
also have speed engineering long tubes with slp exhaust
made it not even halfway through the dyno session and had a lifter start ticking and decided to call it a day.
ordered some ls7 roller lifters "highly recommended" and im also upgrading the cam to a texas speed bfd cam and upgrading to .660 valve springs
soon as all my parts arrive ill go get it dyno'd again and let you know how it goes. BTW- the 228/230 cam that comes with the kit doesn't sound bad at all and has a good lope to it. i just wanted something a little more aggressive
