317 Heads Milled with Cam??
Old Dec 21, 2011 | 07:29 AM
Bigredmachine's Avatar
So you shaved yours .040 and barely had problems so with That EPS Cam I should be ok because its a little smaller and ill be slightly higher then stock compression with about 65cc chambers. Sounds like a winner to me. And of course I'll measure anyways while the motors out of the car. That EPS cam sounds like it should have some pretty nice torque and plenty of power. I'm looking for 11.50 1/4 mile times and I think this is the ticket
Old Dec 21, 2011 | 08:13 AM
1nasty86's Avatar
Turd Gen Guy
Ive seen the 226/234 make some nice power to be its size.
Old Dec 21, 2011 | 05:39 PM
Its still a pretty decent sized cam. Like I said if I can reach 425-440 rwhp with stock or slightly higher compression with these 317 heads and cut an 11.50 or lower ET I will be one happy camper.
Old Feb 10, 2013 | 09:57 PM
JoshuaGrooms83's Avatar
was curious about 317 heads and using .040 x 4.010 cometics gaskets? i plan on running some low boost with em (10psi) but dont want to lose a ton of low end torque due to the lower CR on my 5.7L.
With the above combo inputed into the CR calculator, it gave me 9.9:1 CR but just wanted to make sure that using this thinner gasket is ok?
Old Feb 11, 2013 | 03:58 AM
PREDATOR-Z's Avatar
Flycut and mill for right compression. Do it well or leave it alone.
Old Jun 5, 2013 | 03:01 PM
handyandy496's Avatar
Default clay
I used to get piston marks like that and with .030 valve to piston clay clearance. I think that's from missshits and or weak springs not pulling the valves back up in time getting help from the pistons lol. clay numbers anyone??
Old Jun 5, 2013 | 03:13 PM
Default pushrods
o yeah. After doing ur own flycutting make shure u roll ur pushrods to be sure they are perfectly straight. If bent even a little u will loose power.
Old Jun 5, 2013 | 07:19 PM
1BAD98LS1's Avatar
Always best to flycut pistons while the engine is apart, hell you may get tired of the cam and want to go bigger , and for the minimal cost its best to get hardened pushrods and be done with them as well ( no rolling required lol). This way they too can handle the bigger cam as well when the time comes.
Old Jun 5, 2013 | 11:13 PM
Always2Slow's Avatar
Originally Posted by 1nasty86
well i milled mine .040 and had a guy on here spec my cam 230/238 and this is what i found after running the car for a year with these heads. if i had to do it over again i wouldnt go over a 226 on the intake to be safe on the setup I had.. without flycutting. i just took the heads off saturday and found what is seen in the pic. no harm done to anything thankfully.
I take it you didn't measure your PTV clearence but at any rate those are some nice valve reliefs.
Old Jun 5, 2013 | 11:15 PM
No that is because when things heat up clearances change that is why its recommended to be at .080 clearance or better.
Old Jun 6, 2013 | 01:11 AM
Redbull87's Avatar
I picked up almost 60whp going from stock 317 heads to .030 milled 243 heads on stock gasket and small retune.
Just dont skimp on springs,pushrods etc when you do the cam swap.Should make good numbers if your chasing figures.
Old Jun 6, 2013 | 01:17 AM
  #32
lemons12's Avatar
My old 346 was pretty simple and got me to 7.2s-7.3s @ 95mph or so... 3500# race weight in 2000+DA.
ported/milled 30 thous 317s
226/228 .588 114 cam
PTC 4000
373s
little suspension
ls6 intake/ported tb
1 3/4 headers kooks crappy ORY with cutout into magnaflow
Actually, those heads are for sale.
