what bearings are you guys running?
also what about gaskets? i'm prob gonna end up running fel pro but has anyone else ran any victor reinz gaskets?
The two LS engines we used for the Engine Masters had the same set for both years.
When we tore the engine down from last year the bearings were in such good shape I reused them for this year.
Andy
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Clevite CB663HN Rod Bearings - Narrowed for crank fillet clearance
Clevite SH1814S Camshaft Bearings
Clevite MS2199H Main Bearings
Felpro on the Oil Pan Gasket, Front and Rear cover gasket, and Water Pump gaskets.
Haven't picked intake or head gaskets yet.
I did a quick search (don't know the specifics of your combo, just for comparison's sake), King Tri-metal $145, Clevite Tri-metal $152, Clevite Tri-metal Coated $199. Just FWIW.
I'd stick with Clevite P bearings, inexpensive, been around for years, work just fine.
