what bearings are you guys running?
There is a little truth the the performace bearings causing a crank to wear faster but it has nothing to do with the hardness of the bearing material, the reason is that the performance bearings have no embedability layer. The stock type bearings do and it allows any debris in the oil to be embeded in the soft surface layer of the bearing.
This mainly comes into play on the first startup when the engine is freshly built.
Andy
Andy
EDIT
I just checked Summit again, the only King main bearings they have listed for LS engines are the MB5013XP (Tri-metal grooved upper/lower, $145.95) and they are described as "race-only."
