Hardened Pushrods Worth $100?
Originally Posted by 99SilverC5Coupe
I'm having Comp 921s and a cam with .581 lift installed.. Worth the extra C note to get the hardened pushrods? Are LS1 and LS6 pushrods the same?
Doesnt it mean that you've eliminated a piece capable of protecting your overall valve train in the event of over RPM? After all, a missed shift causing bent push rods isn't that hard/expensive to fix.
With the hardened ones, what will be the first to go? Piston to valve contact b/o valve float? Broken rocker arms or studs. Sounds like it could have some negative potential. The OE ones work fine as long as you avoid the missed shift.
steve
steve
