Oil pump seal to block
Old Dec 22, 2011 | 11:24 AM
turbodarryl's Avatar
Default Oil pump seal to block
Hey Guys, I've installed a double rollmaster chain and I have to use the spacers, do I just bolt the pump to the block with spacers provided or do I have to use some sort of gasket sealer between the spacers, oil pump and block?? And do I just bolt the pump right up or there any adjustments for the pump ???
Old Dec 22, 2011 | 04:06 PM
ttttt, anybody ??
Old Dec 22, 2011 | 04:15 PM
99LSS1's Avatar
You shouldn't have to use any sealer. But you do need to shim the pump... To make sure it is centered. I use .003 and .002 feeler gauges to shim the pumps that I do. Hope this helps.
Old Dec 22, 2011 | 05:17 PM
RARON455's Avatar
You dont need any sealer, Just put the spacers in and thats it. Not sure what 99ls1 means by shimming,He may be referring to what is common practice of removing the front plate of the oil pump, and use some feeler gauges to center the pump gerotor to the main housing, so it is centered,(equal distance on both sides, then tighten down the oil pump mounting bolts, and put the front cover back on. and your good to go. make sure you use the correct O-ring and put some assembly lube, or oil on it before installing the pick-up tube.
I have a melling pump and the double chain from rollmaster my self,,, get ready, I had to do a ton of grinding to the inside of my front cover to get the thing to fit.
Old Dec 22, 2011 | 07:38 PM
Gray86hatch's Avatar
It will leak if you don't seal it.
I use pumps that are cut for a o-ring seal for this reason. Alighning the pump is also a must. You need to center the gears to the crank then the housing to the gears. Just centering the housing to the crank dosn't cut it.
Car Shop Inc has a kit they sell to do this.
Tim
Old Dec 22, 2011 | 08:43 PM
RARON455's Avatar
Stock pumps, as well as melling pumps are not "cut" gm manual says nothing about using any sealer. Have no idea how you could center a splined gear on its matching shaft. First I ever heard of this..however an o ring sealed pump would be a terrific idea and if I knew of one I would run it.
Old Dec 22, 2011 | 10:22 PM
Hey Guys Thanks, I do have a mellings pump and a rollmaster chain and I defiantly had to do my share of grinding inside the timing cover for everything to fit right, I installed the pump and shimmed the gear to housing before torquing it down, thanks again.
Old Dec 23, 2011 | 02:24 AM
bww3588's Avatar
Agreed, you can't center the gears to the crank. And you don't have to use any sealant. If you do, more then likely it will end up in a lifter causing it to fail.
Old Dec 23, 2011 | 02:26 AM
bww3588's Avatar
Even the stock pumps aren't sealed in any way from the factory and they work just fine. I really don't care if it does leak for this reason.
Old Dec 23, 2011 | 04:06 AM
01ssreda4's Avatar
Yep, there are some dumb posts in this thread. Oring'ed pump? Since when is an LS style pump oringed??
Old Dec 23, 2011 | 06:32 AM
A leak is a leak.
Call Tim at the car shop and ask him about his kit. Centering the crank to the rotors to the housing is possible and very easy to do. Just have to have the right feeler gauges and process.
Melling two years ago told me centering the pump was not needed. Well they were wrong.
If anything a thin layer of anarobic sealer would be a good thing.
The GM manual was wrote when??? Some things have changed since then.
Tim
Old Dec 23, 2011 | 07:30 AM
bww3588's Avatar
Originally Posted by Gray86hatch
A leak is a leak.
Tim
wow...
you need to stop while your ahead. GM never sealed them, and do they leak? who knows, and who cares. if it leaks, awesome. they still hold good oil pressure over the life of the engine. I have never seen anyone tear an engine down due to low oil pressure caused by a leaking oil pump to block surface.
find some legitimate proof stating it should be sealed prior to installation, until then, your posts hold no merit in this thread.
Old Dec 23, 2011 | 07:44 AM
Vern schumann (google him) is who does my pumps. The time he spent on the dyno and pump stand he found a leak there and sealing it increased the effiency of the pump. A few little things add up quick.
He has found quite a few other things that allowed engines that were not surviving at the texas mile or in NHRA SS to now have no issues. Prior to this guys were going dry sump.
Again TIm at the car shop sells all of this stuff and has all the details straight from Vern.
Call him you may learn something not in the GM manual.
Tim
Old Dec 23, 2011 | 08:13 AM
bww3588's Avatar
googled him, came up with this.
http://www.enginebuildermag.com/Arti...echnology.aspx
says nothing about leaking between the block and pump being a bad thing unless it causes low oil pressure at idle. the article also states that most engines only need about 10psi/1000RPM (common rule of thumb).
so Vern Schumann just reinforced my earlier statement that there is no real reason to seal your oil pump unless that particular leak (that occurs in EVERY LS engine from the factory) is causing low oil pressure.
more than likely, your low oil pressure woes will be caused by excessive bearing clearance before the a leak between the block and pump does. obviously, the stock pump, in stock unmodified form has enough ***** to overcome this leak and provide enough pressure and volume to feed the engine adequately. (and in most cases, according to Vern Schumann, 4 times more than adequate given the "10 psi/1000RPM" rule and that most LS engines in good condition maintain 40 PSI@ idle.)
now I ask you, do the benefits outweigh the risk? is the extra .5 PSI at idle worth the risk of sending a small bit of sealer thru your filter or other small oil passage, and potentially blocking it? not to me.....I'll continue NOT sealing my oil pumps.
Old Dec 23, 2011 | 08:15 AM
bww3588's Avatar
Also, he also stated that the most common type of leak on the front mounted pumps is between the shitty stock cover and the pump housing itself at high RPM's, which is why melling and other aftermarket oil pump manufacturers use stronger pump covers to prevent that leak.
Old Dec 23, 2011 | 08:26 AM
SweetS10V8's Avatar
The most important thing is when using the spacers for a double roller, be sure you have the spacers oriented correctly so you dont partially block the oil path.
Old Dec 23, 2011 | 09:02 AM
Yes I did notice the spacers can go on wrong if not paying attention, everything went together great, no sealer used here :-) , I'm surprised nobody came out with a custom timing cover for the double row chain setup.
Old Dec 23, 2011 | 10:41 AM
SweetS10V8's Avatar
Old Dec 23, 2011 | 11:25 AM
kpadlina's Avatar
heres how I shimmed my pump. hope this picture helps.
http://img.photobucket.com/albums/v6...s/IMG_0382.jpg
Old Dec 23, 2011 | 04:12 PM
99LSS1's Avatar
You should be good to go then!!!
