What cr should I go with
Old 12-24-2011, 02:13 PM
99slobird's Avatar
Default What cr should I go with
I have a 383 99 Ta that is making 432hp on motor through a 12 bolt and a a3 it has a ported set of 241s, ms3, 102/102. As of right now my cr is a 10.3 with a -10cc piston and a 64cc head and a mls .51 gasket. I bought a set of tfs225s that are currently a 65cc and am going to be usin a .40 cometic gasket. What cr should I go with and run pump gas and still be good for a 250 hit of nitrous. What should my final cc size be on my new heads?
Old 12-24-2011, 02:48 PM
LS1 Tech Administrator
Patrick G's Avatar
A 61cc chamber will get you to 11.0:1 which is a really good place to be for pump gas. That would require around a .024" mill assuming you're running a .040" gasket.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Old 12-24-2011, 04:17 PM
99slobird's Avatar
Well when THE MAN says 11.0 is what I need then that's what I'll go with. Second question. Gm head bolts..... Arp bolts..... Or arp studs?
Old 12-24-2011, 04:36 PM
95ONE's Avatar
BUT. I'm sure you already know this, but lets just restate. That brings your valves that much closer to the pistons. I understand you have dish pistons, but are they fly cut in the right spot for clearance?
If in any doubt, you really need to check your P to V. And then of course you will need different pushrods. Just in case..
Old 12-24-2011, 05:09 PM
Patrick G's Avatar
ARP head studs. Reason? Because if you're going to be running a 250 shot, you'll most likely get into a habit of removing your heads a lot, LOL. Studs make removal and replacement pretty easy.
__________________
Old 12-24-2011, 05:13 PM
99slobird's Avatar
Yea they do have valve reliefs in the them if I'm not mistaken they are a -3Cc inverted dome and the extra -7cc are from the valve reliefs I have the part number if needed also this is a 3.905 bore with a 4.000 gasket I realize that factors in my cr
Old 12-25-2011, 04:57 AM
RezinTexas's Avatar
+1 on the studs for easy head removal / re-installation
