Another Cam suggestions thread
Old Dec 28, 2011 | 09:37 AM
Patrick G's Avatar
LS1 Tech Administrator
Originally Posted by JPH
Use there 228R. That will produce the results that you are wanting.
Originally Posted by A.R. Shale Targa
This is the cam I was thinkin' would be just right or if the OP stumbles
across a good used ThunderRacing224. Both are great street sticks.
Also the OP should try blending the oil pump casting ports and pop a .060"
shim in the bypass spring to kick the pressure up a bit. Just make sure
to put the geroter gears back in the housing the same way they came
out so the non-beveled side doesn't chew up the casting. I'd
consider the PSI maxlife springs if set on the bee-hive style.
Two best quotes of the thread. You need to stay under 230 in duration at .050" to keep your low and mid-range robust and you'll need to stay under .600" lift for reliability with most beehives.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Dec 28, 2011 | 10:19 AM
rggbly's Avatar
I was really interested in the spartan cams that Damian has been spec'ing. They're putting down power I would be happy with. I've been thinking about getting a custom ground cam with the XE-R lobes on the intake and XE on the exhaust. 228/232 with .588/.581 lift and 111 lsa. The only thing I don't understand or know how to spec is the ICL...I think I read in one of his threads between two cams I was looking at that it was a 108 ICL. Pat idk if you'd charge me to "ok" this cam or not but can you tell me what you think?
228/232 .588/.581 111 lsa
intake lobes: XE-R, exhaust lobes: XE
108 ICL
And thanks for chimin in fellas. I will blend the pump when I pull it off to replace the timing chain. I'll do some searching to try to learn a little more about that spring mod your talking about. Thanks guys
Old Dec 28, 2011 | 02:57 PM
Badmeat's Avatar
Not to ***** my thread out, but I think there was a lot of good discussion/info in it that you will benefit from: https://ls1tech.com/forums/generatio...veability.html
Old Dec 28, 2011 | 05:01 PM
rggbly's Avatar
I appreciate it man. I've done a hell of a lot of reading over the two years that I've had this car. I'm looking for the same cam you are...something around high 220's to low 230's duration and below .600 lift. I've seen awesome results time and time again from these set ups. It's so hard to make the final decision though due to the enormous amount of options in the range of camshaft size I'm looking for
Old Jan 1, 2012 | 03:36 PM
Ronny_02_WS6's Avatar
In that case 228R should be the best bet
