pushing my luck?
pushing my luck?
am i asking for trouble if i use my 1218 PAC valve springs with a torquer v2 cam?
springs are good to .600" lift i believe and the cam is rated at .598" lift
If you know that your installed spring height is not under 1.8 then you will be fine. The distance to coil bind (.060) is exactly what most of the more knowledgeable guys/shops would recommend. http://www.racingsprings.com/Store/P...?ProductID=206
