engine bearings
Old Jan 8, 2012 | 02:58 PM
noonzor's Avatar
Default engine bearings
do new bearings look like this? cause these look used to me. these came from the engine shop that did my machine work and are supposed to be new high performance bearings...
Attached Thumbnails engine bearings-yeao-boi-014.jpg   engine bearings-yeao-boi-011.jpg
Old Jan 8, 2012 | 03:09 PM
JPH's Avatar
JPH
Yes, the last set of clevites I used did look like that.
Old Jan 8, 2012 | 03:11 PM
noonzor's Avatar
weird, ive never seen new bearings colored like this. thanks! guess its time to assemble!
Old Jan 8, 2012 | 03:29 PM
JPH's Avatar
JPH
Make sure ALL the bearings have the correct part number markings on them, and that oil clearances are checked/verified per target spec engine calls for.
Old Jan 8, 2012 | 04:31 PM
noonzor's Avatar
ill take a look at them all and make sure the numbers match before i start thanks! i still have to go through my pre-assembly, but all clearences will be checked then checked again before final assembly for sure!
Old Jan 8, 2012 | 11:11 PM
wildcamaro's Avatar
are those the p or the h bearings?
Old Jan 9, 2012 | 01:20 PM
JPH's Avatar
JPH
Those would be "h" series wild. The box even shows that.
JPH's Avatar
JPH
Good deal bud.
Old Jan 9, 2012 | 01:35 PM
5 Liter Eater's Avatar
Jez I would have asked the same thing. Those look like crap.
Old Jan 9, 2012 | 01:37 PM
JPH's Avatar
JPH
Harden/Heat treat process they go thru.
Old Jan 9, 2012 | 01:52 PM
513camarors91's Avatar
guess you learn something new everyday bc i would have thought they we used too...
Old Jan 9, 2012 | 02:04 PM
wildcamaro's Avatar
I guess I should of looked at box lol. But they look like a super high quality bearing for sure!
Old Jan 9, 2012 | 06:30 PM
chrisfrost's Avatar
Maybe in the future You buy You're engine parts per what You're builder tells You ,,,,,,,,,,,,they sure do appear to have products of combustion stains on them but if guys on here say they're new then I guess they're new .
Old Jan 9, 2012 | 08:38 PM
wildcamaro's Avatar
If you have the special bearing dial calipers you could verify thickness
Old Jan 10, 2012 | 02:28 AM
chrisfrost's Avatar
You can measure thickness with a dial caliper that has resolution to .001" accurately . Just make sure You use the thin part of the caliper, not closer to the dial where it's thicker to measure with .
