Need help identifying this Cam!!!
Old Jan 17, 2012 | 07:10 PM
jfg429's Avatar
Default Need help identifying this Cam!!!
I bought a build 402 with this cam but searched in the web and cant seem to find a specific cam on these numbers engraved on it...Anyone familiar with it?I want to know the specs on it...Thanks
Old Jan 17, 2012 | 07:31 PM
wildcamaro's Avatar
It isnt a Comp Cam I can tell you that
Old Jan 17, 2012 | 07:38 PM
jfg429's Avatar
Ok but what can it be??? im still searching but cant find anything with these #s
Old Jan 17, 2012 | 07:40 PM
Prorac1's Avatar
Start checking differant manufactures grind numbers. Comp, Crane, etc. Thats where you will find your answer. The previous owner didnt know what the cam was? Eric L
Old Jan 17, 2012 | 07:43 PM
jfg429's Avatar
yeah he remembers somewhat but since he lost his cam spec card i just wanna make sure what it really is without any guess.....
Old Jan 17, 2012 | 08:00 PM
S10xGN's Avatar
Thirty seconds on Google found this. The only difference is the LSA...
Old Jan 17, 2012 | 08:07 PM
jfg429's Avatar
Thanks i couldnt figure out what numbers to start searching by...
Old Jan 17, 2012 | 09:52 PM
Unaffliated Racing's Avatar
Yeah def a comp cam, made back in 2008
Old Jan 17, 2012 | 10:09 PM
JPH's Avatar
JPH
242/248 .610/.615 114 (XER Lobes)
Old Jan 17, 2012 | 10:52 PM
jfg429's Avatar
JPH- were did u get this specs?? Is it an excact match in pn#
Old Jan 18, 2012 | 10:30 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
242/248 .610"/.615" (with 1.7:1 rockers) 114LSA
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Jan 18, 2012 | 11:41 AM
SweetS10V8's Avatar
Engraved CC = Comp Cams
http://www.compcams.com/Technical/Ca...obeCatalog.pdf
Search the lobe numbers, 3731 & 3134 (in pdf linked above)
HR114 = Hyd Roller 114 LSA
N2090-08 = Serial number if you want to call Comp and get a cam card, or have them tell you more.
Old Jan 18, 2012 | 11:45 AM
sepsis's Avatar
I think Wild was being sarcastic.
We need a sarcasm smiley added, like this one. It's called "dodgy"
Old Jan 18, 2012 | 03:34 PM
JPH's Avatar
JPH
My Comp Cams "lobe master catalog".
