slack in timing chain
Subscribe
Jan 19, 2012 | 10:45 PM
so the hd timing set i ordered isnt a ls2 chian? when you say dampaner you talking about the timing chain tensioner that's in aluminum blocks? im running a iron 5.3 truck block that isnt drilled and tapped for it.
Reply 0
Jan 19, 2012 | 10:46 PM
Quote: so the hd timing set i ordered isnt a ls2 chian? when you say dampaner you talking about the timing chain tensioner that's in aluminum blocks? im running a iron 5.3 truck block that isnt drilled and tapped for it.
you would have to drill/tap for the damper
Reply 0
Jan 19, 2012 | 10:56 PM
i think thats gonna be a last resort how easy of a job is it? i already have the motor apart.
Reply 0
Jan 19, 2012 | 11:08 PM
the hardest part of getting the damper in would be getting in center in the timing chain so that it dosnt rub either side.
Reply 0
Jan 19, 2012 | 11:44 PM
if you have the block out and apart and dont feel 100% confident you will get it 100% correct the first time take it to a reputable machine shop and have them drill and tap it for you. They shouldn't charge more than 40 bucks or so to do that
dampener is good insurance against snapping your chain if you beat the tar out of your motor
Reply 0
Jan 19, 2012 | 11:45 PM
yes the timing chain tensioner/dampener
Reply 0
Jan 20, 2012 | 05:43 AM
Quote: Hd ls2 chain on left oe ls2 on right.u be the judge
what is the HD chain?
Reply 0
Jan 20, 2012 | 10:03 AM
For about 10-15 bucks more u can get an OE. I wouldn't do aftermarket, especially when building an engine. Chain is the link that holds all together.
Reply 0
Jan 21, 2012 | 03:18 PM
i think the one of the left is the hd chain
Reply 0
Jan 21, 2012 | 03:20 PM
im just worried bout the slack in the timing chain im waiting on a nother timing set from advanced to get in. if it dosnt have as much slack as what the hd timing chain does ill run it. dont wanna have to worry bout my timing chain breaking
Reply 0
Jan 21, 2012 | 07:24 PM
i built my motor about a year ago and have been spraying 150 on it with about that much slack in it and have had no problems out of it. i have also replaced chains and gears on other 5.3 trucks and had no problems and they have all seemed to have about the same slack as yours
Reply 0
Jan 21, 2012 | 07:34 PM
  #32
i had less slack on my stock chain when i pulled it at 130k miles.
Reply 0
Jan 21, 2012 | 11:39 PM
  #33
Quote: i bought it from a guy on here. its all new. with the billet cam sprocket. do i just need a new chain or what?
That's not a billet cam sprocket in the video. That's a stock Cloyes LS2 timing set.
Quote: seems like more slack than i have seen but to be honest i have taken apart several LS2's that have near that much slack.
I've built several LS based engines and they never had this much slack either.
Reply 0
Jan 22, 2012 | 12:24 AM
  #34
Thats what i said it doesnt look billet to me or The hd chain doesnt look any better then my stock oe ls2 chain.ill be pm The seller here soon.
Reply 0
Jan 22, 2012 | 02:40 PM
  #35
Don't want to sound like an advertisement, but I was in the same boat.
I'm doing a build right now and went back and forth trying to figure out what to do about the slack in my Yank set with an LS2 chain. It was about the same as what you show but only had ~2500 miles on it. I went with a Cloyes Hex-a-just because they use a slightly larger crank sprocket to take out some of the slack. You also get a thrust bearing and the infinite adjustment is nice too. High quality piece, and there is almost no slack in the chain whatsoever.
Reply 0
Jan 22, 2012 | 06:46 PM
  #36
I just got done installing a new cam motion cam today, and I also went with the Cloyes Billet true roller Speed set, and I now have very little slack in my timing chain now. I could not believe how lose my old set was.
Reply 0
Jan 22, 2012 | 07:49 PM
  #37
i bought a new set from advanced and the chains look the same. gears look different though.
Reply 0
Jan 22, 2012 | 08:01 PM
  #38
what the add says...
New GM LS complete timing sets
set contains :
Gm crank gear, Gm 3 bolt cam gear for use on LS1, LS2, or LS6 and The LSA/LS9 super HD chain and special Bolts
This is the LS2 HD set that will fit and work great on the LS1 or LS6 engines as well as the 4.8,5.3, 6.0 truck engines
for some reason i thought it said it came with a billet cam gear.... guess i was wrong.
Reply 0
Jan 22, 2012 | 10:14 PM
  #39
I posted a thread post, but it was for LT1 sorry. It talked about an oversized crank sprocket.
Reply 0
Jan 22, 2012 | 10:26 PM
  #40
set contains :
If you're talking about the set you get from Yank, they have it, you just have to ask. I don't even think the option is more than 10 bucks extra.
Reply 0
