pcv valve fix question
Old Mar 17, 2004 | 09:51 PM
Jpr5690's Avatar
Default pcv valve fix question
okay i did the fix for my pcv valve where you put the air\ moisture seperator in line after the pcv valve on route to the throddle body ive had it on there not for like 50 miles and all seems good i do see a minute and i do mean minute sliver of oil on the side of the container where the oil is suppose to collect. but my question is i mounted the the "catch can" to my stb which makes the hose from the pcv valve have to run at a steap incline to reach the filter and then a decline to the TB will this cause any problems... my fear is that some pooling might occour in the line between the pcv valve and the filter causing the air flow to be restricted thus causing the engine to not properly ventwhich would suck ... so i guess im saying will the oil that dont make it up the incline flow back into the crank case or just sit in the hose between the valve and filter and mess things up ???
Old Mar 18, 2004 | 01:38 AM
x phantom x's Avatar
STF veteran / 10 second club
The air should push the oil through, unless there is a HUGE amount of oil.
Upload a picture of it so we can see how bad it is. Btw, why don't you just cut the hose alittle shorter, or make it line up better?
Old Mar 18, 2004 | 09:29 AM
Jpr5690's Avatar
ill puload a pic but the actual filter is mounted above the pcv its strapped to my stb right above my oil cap so the hose running from valve to the filter has to travel at a incline to meat up with the filter the only way to resolve this is to mount the filter lower than the pcv valve but it will look like crap and be hard to access if i do that so thats why it is where it is
Old Mar 18, 2004 | 09:41 AM
Jpr5690's Avatar
http://www.cardomain.com/memberpage/439277/3
Old Mar 18, 2004 | 09:42 AM
Jpr5690's Avatar
Thats A Link To A Pic Of The Pcv Mod I Did Please Check It Out And Give Opnions On If Its Ok
Old Mar 18, 2004 | 09:44 AM
TaTommyWS6's Avatar
I don't think the positioning will be a problem at all. My only concern is the size of the "can". You are really going to have to check that often.
Tommy
Old Mar 18, 2004 | 02:53 PM
Jpr5690's Avatar
i dont drive much and so far virtually nothing has showed up in there
Old Mar 18, 2004 | 02:54 PM
Jpr5690's Avatar
i drive like 4k a year
Old Mar 18, 2004 | 07:43 PM
Jpr5690's Avatar
Ttt Need More Opnions
Old Mar 19, 2004 | 05:47 PM
Jpr5690's Avatar
Man Dropping Fast No More People Have Information About This?
