Patriot 8501 .660" Valve Spring Ruined multiple valve seals
Old 01-22-2012, 12:51 PM
nahasapeemapetalon's Avatar
Default Patriot 8501 .660" Valve Spring Ruined multiple valve seals
I installed new Patriot valve springs and seals last year. In taking the heads apart i found some valve seals where chewed up and went through the motor. Some others were moved up the valve stem. As far as i know i seated them all properly. IIRC the seals came in the patriot spring kit.
Has anyone had this problem? I wonder if it had anything to do with the diameter of the seals?
What seals do you guys order, i assume replacement GM seals? I have 317 heads.
Ill post up some pictures soon
Old 01-22-2012, 12:56 PM
studderin's Avatar
how much retainer to seal room did they have.
Quick Reply: Patriot 8501 .660" Valve Spring Ruined multiple valve seals
