Can a 2.00 intake valve be used on a 5.3 cylinder head?
Title says it. I've read some posts that say yes and some that say no so I haven't been able to find a clear answer. If the answer is yes, what kind of work would be involved in making it happen? Thanks.
Also a 2.00" valve in a 5.3L head will be really close to the edge of the combustion chamber thus will be somewhat shrouded . So if it will be used in an engine with a larger bore than 3.779" then You can easily enlarge the combustion chamber to match the bore .
