Would you run this?
Old Jan 26, 2012 | 04:30 PM
outkast6991's Avatar
Default Would you run this?
Looking for some opinions as to whether or not this cam is still worth puting back in. it seems like a piece of my broken spring must have gotten between the lobe and lifter to me. It will be looked at buy my head guy but i'm curious what you guys think
Old Jan 26, 2012 | 04:45 PM
wildcamaro's Avatar
I wouldn't, that stuff is machined smooth for a reason...be safe and replace...
Old Jan 26, 2012 | 05:12 PM
ksk1980's Avatar
In the same boat timing chain snapped and a pc if it lodged itself in there. Ruined a cam with less than 1500 miles timing set was new at time of cam install also. :/
Old Jan 26, 2012 | 05:29 PM
Mine has under 8000 on it. Broken spring is turning into an expensive PITA
Old Jan 26, 2012 | 05:46 PM
Sales1@Texas-speed's Avatar
Definitely would choose to replace that.
Old Jan 26, 2012 | 05:55 PM
RezinTexas's Avatar
No....
Old Jan 26, 2012 | 06:01 PM
Doug G's Avatar
Can you catch it with a fingernail ?
Then NO !
Old Jan 26, 2012 | 06:10 PM
1ltcap's Avatar
absolutely not. replace it.
Old Jan 26, 2012 | 06:20 PM
I was thinking it was junk but hoping it wasn't. Looks like I'll be shopping for a cam then
Old Jan 26, 2012 | 07:46 PM
Doug G's Avatar
Wall hanger
Full race cam LOL
Old Jan 26, 2012 | 08:15 PM
trans_am7935's Avatar
make a lamp out of it, or use it as a hammer!
Old Jan 26, 2012 | 08:28 PM
513camarors91's Avatar
i would rather be safe than sry if i were you...unless you have money to replace the motor if it fails
Old Jan 26, 2012 | 10:29 PM
2000PewterT/A's Avatar
I would replace it with out a doubt
Old Jan 27, 2012 | 08:44 AM
i'm gonna junk it. this whole build/repair is leaving a bad taste in my mouth. i broke a 1518 at part throttle. pulled the heads and the other 15 springs were down on pressure and rate. PAC and my head guy ask for cam specs so i email FTI. FTI wont give the specs needed to id the lobes for fear of somebody copying his work. he says the lobes were made for a beehive though. so my only option was to pull the cam and have it doctored. so i pull it to find this
Old Jan 27, 2012 | 02:01 PM
Droptopws6's Avatar
Old Jan 27, 2012 | 04:58 PM
spaulsen's Avatar
nice! how u get the wires up the cam?
Old Jan 27, 2012 | 05:18 PM
wildcamaro's Avatar
That's one awesome lamp! Made of only the finest billet!
Old Jan 27, 2012 | 06:00 PM
Well if anybody wants to buy a lamp base let me know
Old Jan 27, 2012 | 07:34 PM
S10xGN's Avatar
Guess who's never seen an LS cam. They are all gun-drilled. Well, not sure about the VVT cams, but all Gen III's are...
Old Jan 27, 2012 | 08:08 PM
here you go, for all you bolt on guys
