are both head gaskets the same on 98 LS1
Old Jan 31, 2012 | 01:20 AM
_blake's Avatar
Default are both head gaskets the same on 98 LS1
hey, I have a stock 98 LS1 that I pulled the head off of. I went to vic hubbard to get head gaskets and they gave me 2. When I put them on the block one side has "front" that points forward, the other has "front" but it points to the rear.
Dose the driver side take a diff gasket pass?
Old Jan 31, 2012 | 02:03 AM
bww3588's Avatar
Flip it over. Front always goes on the front of the engine.
Old Jan 31, 2012 | 03:17 AM
baxsom's Avatar
doesnt those heads have a notch on the underside that require a specific headgasket direction per side?
Old Jan 31, 2012 | 04:01 AM
bww3588's Avatar
I thought the 853's had the notch.
Old Jan 31, 2012 | 04:18 AM
butler's Avatar
front means front whether or not you flip it over.
Old Jan 31, 2012 | 05:55 AM
bww3588's Avatar
You don't have a choice, if he just turns it around it will be upside down. It has to be flipped over.
Old Jan 31, 2012 | 05:13 PM
_blake's Avatar
This is exactly what I need to know. So it will not matter if the gasket is flipped over?? Do they sale a left and right handed gasket?
I don't think all the holes line up when upside down.
I will take pix of what I'm doing when I get home.
Old Jan 31, 2012 | 10:38 PM
_blake's Avatar
See the holes don't line up when the gasket is on rite side up...
http://i12.photobucket.com/albums/a2...1-31184122.jpg
But they line up fine when its upside down
http://i12.photobucket.com/albums/a2...1-31184204.jpg
Is there any harm in installing this way? Or is there a proper gasket that I need to get?
Old Feb 1, 2012 | 02:31 AM
baxsom's Avatar
98s have the 853s dont they? i know my 00 does.
Old Feb 1, 2012 | 03:14 AM
bww3588's Avatar
97 and 98's have 806 perimeter bolt valve cover heads.
Old Feb 1, 2012 | 09:39 AM
black00ssFL's Avatar
If they are graphite gaskets, they are side specific. Check the head you pulled, along the edge there may or may not be a recessed area. If you HAVE the recessed area, you need the graphite gaskets (which are side specific). If you DO NOT have the recessed area, you can use the mls gasket (which are NOT side specific).
