Did serious damage occur?...opinions needed (Pics and vids)
I'm not sure why your doing a leak down. Theres coolant in your oil. The heads need to come off no matter whats wrong with it. A visual inspection will tell you exactly whats wrong when the heads off.
The 1st thing would be to take off the valve covers. If its not in the valvetrain(Rockers, springs, pushrods) the heads need to come off.
yea, the only thing to worry about, is like i said.....if the piston's not at bdc, it's gonna get there fast....and anything near anything rotating is gonna get flung...or caught in a belt. i used to use the leakdown testers, but it just seemed to me to be another step. that's why i told him to just run shop air to it.
OK so this is where I'm at so far, I haven't got to do much considering I've been pulling long hours at work. But I read all everyone's advice and am still getting around to doing the different things recommended. Thank you all for the help so far. I pulled all the plugs, which ended up being very time consuming considering I didn't have a lot of the needed wrenches/sockets and every place is closed by the time I actually get to work on the car. BTW my hands look like they've been drug down the street now haha. Also, pulled the coil packs, and valve covers, so I could take a look around like suggested. Pics are below. Next step I'm going to do the compression test and then drop the oil pan, and go from there.
Spark plugs in order:
2-4-6-8
1-3-5-7
![](http://i41.tinypic.com/29crnli.jpg)
Passenger side, valve cover removed:
![](http://i41.tinypic.com/r05ldi.jpg)
![](http://i43.tinypic.com/vpyosg.jpg)
![](http://i41.tinypic.com/200u24h.jpg)
![](http://i44.tinypic.com/2rglyxs.jpg)
Driver side, valve cover removed:
![](http://i43.tinypic.com/ieldza.jpg)
![](http://i39.tinypic.com/257m6nb.jpg)
![](http://i41.tinypic.com/10moqh1.jpg)
Please keep the opinions coming, I'll keep updating as a go along.
2-4-6-8
1-3-5-7
2-4-6-8
1-3-5-7
2-4-6-8
1-3-5-7
Looks kind of rich. (which doesnt explain anything else) just an observation. 7 does look like it has a larger gap but hard to tell in pics.
Not argueing the head gasket theory but if it was generally wont they turn the plugs a whiter color because it cleans them off. (pretty much steam cleans them) and some signs of rust. Especially if he has took days to touch it. Makes me almost think the smoke is more an oil issue like broken ring than head gasket.
UNDER PRESSURE MOD
The million dollar question is what caused the gap on #7 to get so large? That's definitely going to cause a misfire on #7 with what looks like a 0.060" - 0.070" gap.
Hell, if it were me, I'd toss in some new plugs, put it back together, and see how it runs, but then again, I just cracked the ring land on #7 and proceeded to drive it 40 miles home without causing any more damage.
#32
Did you just install the heads or have they been on there for a while?What kind of head gaskets you got on there?Sounds like a gasket.Deffinately do the radiator cap test before you start pulling it apart.
