Will I have ptv clearance issues with this combo?
Old Feb 1, 2012 | 11:31 AM
Mr. Trick's Avatar
Default Will I have ptv clearance issues with this combo?
I bought some ported ls6 heads that have not been milled, the heads are bare, but cam with 2.02 intake valves that I am debating on installing. The cam I have in my car right now is a MTI X1 230/227 .590/.570 112 lsa, will I be ok running the ls6 heads with the 2.02 valves or do I need to run stock intake valves? I dont want to spend the cash to have the heads machined for the 2.02s if I am going to have to have to fly cut the pistons. Also I will be useing stock thickness head gaskets.
Old Feb 2, 2012 | 10:33 AM
Mr. Trick's Avatar
Nobody has any input?
Old Feb 2, 2012 | 10:35 AM
outkast6991's Avatar
You should be ok but the only way to know for sure is to clay it
Old Feb 2, 2012 | 10:43 AM
farmington's Avatar
What he said. When you start to change multiple things, you HAVE to check and measure. No way around it. that is, unless you're a betting man .....
Old Feb 5, 2012 | 11:00 AM
Mr. Trick's Avatar
I guess I will clay it just to double check. Also can I run the car without getting it re tuned?
