spraying with stock bottom end
Old Feb 4, 2012 | 08:55 PM
WORKINPROGRESS's Avatar
Default spraying with stock bottom end
Okay so I am currently putting down 426 wheel hp and I'm wanting to spray a 150 shot... Just wanting to make sure thats gonna be safe at the current power I'm putting down? What the most you would spray on a stock bottom end with that power out put?
Old Feb 4, 2012 | 09:00 PM
trans_am7935's Avatar
what size injectors do you have?
specs of your cam?
compression ratio?
Old Feb 4, 2012 | 09:08 PM
specs of your cam?
compression ratio?
gonna be ordering injector when I get the kit...thinking about going with 42lbs...
cam is a 238/246 .624/.624 114LSA
compression is at 10.5:1
Old Feb 4, 2012 | 09:12 PM
Track_FC's Avatar
Sounds pretty aggressive but I'm still a noob. 150 shot is quite a bit.
Old Feb 4, 2012 | 10:58 PM
01ssreda4's Avatar
575 whp is a lot for the stock bottom end. I'd say a 100 shot and a damn good tune will be a safer bet for the long run.
Old Feb 5, 2012 | 12:29 PM
1999BlueTA's Avatar
Do it spray 150 your cam will love it, get a good tune and you'll want to bump up the shot a little later on!!!
Old Feb 5, 2012 | 12:33 PM
1999BlueTA's Avatar
Forgot to add but also atleast upgrade your fuel pump if u have'nt already and you probaly should have posted this in the,nitrous sub forum more helpful info there!!!
