Need help IDing a spring from MTI cam package
Old Feb 4, 2012 | 08:31 PM
jdhommert's Avatar
Default Need help IDing a spring from MTI cam package
I have a MTI stealth cam II that was bought as a whole cam kit from MTI way back in the day. They aren't in business anymore, and I really need to find out what kind of springs they used to use in their cam packages. Do any old school guys here remember?
Its a single spring obviously..the springs look to have a yellow stripe on them iirc..i can post pics if that helps?
Old Feb 10, 2012 | 06:08 PM
jdhommert's Avatar
Can anyone help?
Old Feb 10, 2012 | 06:19 PM
mattster03's Avatar
I found the chart about halfway down this page to be really helpful in ID-ing my springs. You'll need a set of calipers...
http://www.thirdgen.org/techboard/lt...t-numbers.html
Old Feb 11, 2012 | 09:31 AM
TXZ28LS1's Avatar
I am running an old MTI cam as well. I have comp 918 springs if that is what your asking. I believe any cam under .600 lift this is the spring they used.
Old Feb 11, 2012 | 11:11 AM
Mazzenger's Avatar
They also used Manley springs.
Old Feb 11, 2012 | 06:54 PM
PREDATOR-Z's Avatar
I use to run that cam with 918s, Pac 1518 or PSI will do as well. It is a XER Compcam lobes.
224/220 ,581/.581 116LSA
