Custom EPS Cam + 243 build. Look inside
#41
BTW, I hope youre right though... ![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
I guess people just assume I'm a dumbass and I'm going to run the car lean? It has a wideband and I use EFI Live.... I will be monitoring AFR and Injector Duty Cycle at all times.
IF IT NEEDS INJECTORS I WILL BUY THEM
#42
Can't say it will happen to you but don't skimp out on the lifters. *cant remember if you said you were gonna get them or not*
Motor #1 had a lifter break go sideways and bury itself into the block taking out the rest of the motor *go figure*
LS7 lifters are a great, and affordable choice. Backed up with ls2 lifter trays.
#48
Heres a video showing the wideband.
Doesnt look like the injectors are having trouble keeping up to me....
http://www.youtube.com/watch?v=_Xpd6XLApaY
