EPS cam vs. TSP cam
Give us a shout and we can get you setup. We test every cam we have in our line-up on our engine and chassis dynos and we know what it takes to make the power advertised. We have well over 400 camshafts on the shelf ready to ship, and we can have Comp cut a "custom" grind if that tickles your fancy too
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
the valve job. Once you know what the exhaust/intake flow ratio is then you
can call EPS or TSP to determine how much split duration you need.
Cams with 10 or 12 more ex duration help stock heads which only have a 60%
ratio. If you spent more time on your exhaust ports you may only need
a 230/234 which will help the PTV clearance.
