Post your forged 347 builds here...
Old Feb 21, 2015 | 08:29 PM
slownova73's Avatar
Originally Posted by BC178
Haha. I'm just worried once I get it on the dyno it will disappointed. Shop told me they will only use methanol/water injection as a cooler (idk of that's going to affect my goal) and right now 50/50 on a set of 317 heads I have or buying Prc 225cc heads..
Come on guys get in here and give some numbers. Hp/psi/et... any and all
if you could afford it id get go ahead and spend the money on heads, thats where it will count the most, i saw somewhere on here a few years ago, a video of a TA making 1k rwhp on a 347, so i know they can put it down.
Old Feb 21, 2015 | 08:47 PM
Rise of the Phoenix's Avatar
If it's FI, don't worry about spending the money on heads. For FI, 317's will be plenty.
Old Feb 21, 2015 | 10:51 PM
Kbodls1's Avatar
Short block:
-'02 LS1 block bored .005 over, decked .008, lined honed
- stock crank polished, balanced
- Wiseco forged pistons .090 dome (puts me at 11.5:1)
- stock "dipped" rods (I know it's not a "forged" 347)
- LME billet reluctor ring
- ARP main studs
- clevite bearing
- melling high pressure oil pump
- Manley double timing chain
- tick cam 235/239 .623/.623 112+2
LME assembled
Heads:
- ported 241's
- milled to 64cc chamber
- hollow stem intake valve/sodium filled exhaust valve
- 3 angle valve job blended in runners
- stock rockers with tunnion upgrade
- PAC 1518 springs
- ARP head bolts
- stock thickness MLS head gasket
- Stock style lunati lifters
- trickflow pushrods
- LS6 intake (for now)
- 36 lbs. Injectors
should have finished and running by tomorrow night
Old Feb 22, 2015 | 02:02 PM
poltergeist 02's Avatar
never mind, post deleted, I'm not forged.
Old Mar 5, 2015 | 12:36 AM
BC178's Avatar
Nice setups. Keep em comin
Old Mar 5, 2015 | 02:45 AM
Tony @ Mamo Motorsports's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
I'm building one to feature my new MMS 220 heads to hopefully show case their capabilities.
The only reason I went forged is to stick a reasonably sized cam in it to test on the engine dyno (I may test a 220's cam and a mid 230's cam). I didn't want to be on the edge of a potential issue with P to V not having the valve reliefs in there.
I want the engine to be streetable.....not just looking to punch a big number. I'm also hoping for a wide flat torque curve and those who have followed my work over the years know I can coax alot out of an engine that's still a pleasure to drive.
Will have it on Westech's dyno in a couple of months at the most (or at least that's the goal!).
Its pretty basic honestly with the typical Mamo recipe components to aid in power and reliability ( I want a perfectly arced power curve that looks like a solid roller to 7200 or so)....OEM crank....Callies rods.....Wiseco flat tops with valve reliefs....Yella Terra M10 rockers....Manton pushrods and Johnson limited travel lifters. Will mill the heads for 11.5 CR....ported FAST 102 and a 102 TB.
Pretty much the same set-up a guy could install with his OEM un-forged block....the smaller cam not needing any flycutting....the larger cam for the guy getting more aggressive that's willing to flycut or go with an aftermarket forged piston.
I'm hoping to make 560-575 HP at the crank (which would be 1.65 ish HP per cube)....we shall see. And there is a good chance I will offer the finished engine for sale once I'm done with the testing....just depends on whether I come up with anything else viable to keep it for further R&D.
Will have video, pics, and a very thorough thread concerning the build once its complete. Will probably get the thread started before I hit the dyno as the engine is going together
-Tony
__________________
www.mamomotorsports.com
Tony@MamoMotorsports.com
Anything worth doing is worth doing well. Build it right the first time....its alot cheaper than building it twice!!
Old Mar 8, 2015 | 11:42 PM
BC178's Avatar
^ nice
Old Apr 14, 2015 | 09:43 PM
BC178's Avatar
Went Callies rods, wiseco -11cc pistons, stock crank, Prc 225cc heads 62cc chambers. Now trying to decide between ls9 head gaskets or cometic .040..
Old Oct 30, 2015 | 07:34 PM
BC178's Avatar
Not sure who has numbers but mine won't see a dyno till spring. Really hope the motor does good. Have heard few guys getting 9-950 whp, been told long as it's just here and there woth race fuel it will last. Guess if blows and internals are still good might do an iron 347 and reuse stuff. Hoping for mid 9's settle for upper 9's.
Old Feb 3, 2016 | 06:17 PM
dvmeter's Avatar
I'm gonna follow this older thread as well in case there's any more updates. Weighing options for my car. Originally gonna do 408 but if I can use my current LS1 and build it up as 347 with stock crank and reach desired numbers then I'll do that for cost savings vs buying another engine or even just a crank for 383.
Old Feb 5, 2016 | 08:46 AM
snapdude's Avatar
Default Forged 347
Seeing as this thread is back from the dead I figured I'd post my recently completed 347 build here for people to gain info from.
Bottom end:
-99 ls1 block bored .007 over, align honed, decked, and dipped.
- polished stock 99 ls1 crank
- JE 3.905 -22cc dished 2618 forged pistons with JE rings
- Scat 6.100 forged h-beams with arp 2000 bolts
-clevite and king rod/main bearings
- tick performance blower stage 2 v2 cam
- comp short travel link bar lifters
- tick performance hardened pushrods
- melling oil pump
- cloyes billet timing chain
- gmpp oil pickup tube
- stock f-body oil pan and windage tray
- ATI balancer
- TSP 1 7/8 stainless headers
Top end:
- Ported 243 heads
- cometic .040 head gaskets (9.2:1 compression)
- ls1 rockers with comp trunion upgrade
- new stainless valves and guides
- tick performance PAC .660 double springs
- titanium retainers/locks
- 80lb injectors
- ngk tr6 plugs
- msd wires
- ls1 valley cover and steam tubes
- ported ls6 intake
- ported ls1 throttle body
Go fast goodies:
- D1sc procharger
- blower 3.4 pulley
- twin A2A intercoolers
- ATI big red race valve "open"
Lots of other goodies, but can't give away all my secrets! I go for the final tune on Monday the 8th at CSP in west chester.
Old Feb 5, 2016 | 01:41 PM
  #32
dvmeter's Avatar
Whoa. Very nice build. Curious to see the numbers it puts out.
Old Mar 24, 2017 | 08:18 AM
  #33
SRfastZ's Avatar
I'm looking into a 347 build myself. What's the dyno numbers on everyone build ?
Old Mar 24, 2017 | 08:18 PM
  #34
JakeFusion's Avatar
Super Hulk Smash
This is what I've started to build:
Molnar 4340 Forged 3.622" Stroke Crankshaft w/24X Reluctor
Molnar 4340 Forged 6.125” Turbo H-Beam Rods w/ARP2000 Bolts
Diamond 2618 Forged 3.905" R-Series Pistons w/8.6cc Dish 11503-R1
Total Seal AP 1.5/1.5/3.0mm Gas Nitrided Steel Ring Package
Trend H13 .185" Tool Steel Wrist Pins
Clevite MS2199H H-Series Main Bearings
Clevite CB663HN H-Series Rod Bearings
ARP 234-5608 Main Stud Kit
ARP 234-4316 Head Studs 12 Point (LS1/LS6)
GM LS9 4.100" Bore .051" Compressed Head Gaskets
TEA Stage 2 LS6 Heads 62cc w/LS3 Turned Down Intake Valves
PAC 1904 Dual Valve Springs w/Ti Retainers (Shimmed to 160lbs Seat)
BTR Blower Cam 227/244 .612"/.595" 115+5 LSA
Manton 11/32" x 0.120" Wall 7.557" Length Hardened Pushrods
Johnson 2126LSR .058" Short Travel Hydraulic Roller Lifters w/Axle-Oiling
GM LS1 Rocker Arms w/Straub Bronze Trunnions
Rollmaster Billet Double-Roller Adjustable Timing Set
Synergy Ported LS4 Oil Pump
Improved Racing Racing Oil Pan Baffle, Crank Scraper & Windage Tray
Will be looking for 800rwhp with 93+meth with a D1SC.
Old Dec 21, 2017 | 10:19 AM
  #35
snapdude's Avatar
Bottom end:
- melling oil pump
- ATI balancer
Top end:
- Ported 243 heads
- 80lb injectors
- ngk tr6 plugs
- msd wires
- ported ls6 intake
Go fast goodies:
- D1sc procharger
- blower 3.4 pulley
update: Added snow performance stage 2 meth injection with high flow pump and 2.5 gallon tank out back and single #6 Nozzle.
put down 700+ on the dyno
Old Dec 21, 2017 | 09:05 PM
  #36
BC178's Avatar
Snapdude what psi ? Still some left in it or that max you could go? Curious. Not bad
Old Dec 22, 2017 | 07:30 AM
  #37
snapdude's Avatar
Peaks 15.5 psi at 6700, shift at 7000 (I have the aster bracket, was unable to control belt slip after 12 psi on stock procharger j-bracket). However this year I have pulleyed down to 3.4, I know my previous post states 3.4 pulley but its really 3.55 at the moment, i was mistaken. With the 3.4 Pulley I will be overspinning the D1 by about 4% at 7000. Also I have modified the procharger inlet to accept two filters instead of one. So that should free up some more psi as well. Hoping to break 17 psi this year. My big issue is my lower compression motor, I went with deep dished pistons to lower compression to stay "safe" but ended up with like 8.9-9:1 compression. I'd like to get back closer to 10 next year.
Old Dec 22, 2017 | 07:32 AM
  #38
snapdude's Avatar
Side note, I see we have the same S60 rear and 3.54 gear. Have you had any trouble not reaching peak rpm in 4th in the 1/4? I've been wondering if i need to go 3.73 or higher to be at max rpm through the trap. Also, any suggestions for drag wheels and tire setup? We have very similar builds.
Old Dec 22, 2017 | 08:38 AM
  #39
AnotherWs6's Avatar
Snap dude - who is your tuner? I see you said they are in west chester. West Chester PA or NY?
Old Dec 22, 2017 | 08:39 AM
  #40
snapdude's Avatar
Complete Street Performance in West Chester PA, awesome dudes, been going back every year for updated tunes.
