GEN-III cam base circle??
Old 03-19-2004, 08:24 PM
FASTONE's Avatar
Default GEN-III cam base circle??
What's the base circle of ls1 cam and what is cam bearings journal diameter?What is the most lobe lift without reduced base circle?All info appreciated!!
Old 03-20-2004, 06:47 AM
FASTONE's Avatar
I know it's somwhere around.385 but I'm not sure ,anyoneknow,please!!!I mean most lobe lift without reduced cam base.
Old 03-20-2004, 07:18 AM
BYE RICE's Avatar
Whatever it is...'02 & up LS6's are .050" smaller..
Old 03-20-2004, 12:04 PM
racer7088's Avatar
The only way to get more lobe lift is to reduce the base circle. The LSx has a huge base circle of over 1.500 stock so this is no big problem usually.
Old 03-20-2004, 09:54 PM
Larry's Avatar
The base circle of my 98 factory cam was 1.552, .495/.495 lift diameter. An 01 LS6, .525/.525 lift cam is 1.520. My Comp 218/218, .528/.528 lift is 1.540. A Thunder 224/224, .563/.563 lift is 1.495+/- .002 approx. Not sure about the journal diameter.
