Internal trouble... Ideas??
Old Feb 11, 2012 | 02:42 PM
CHADsterss's Avatar
Default Internal trouble... Ideas??
I was driving my car down the road today and noticed a ticking sound, and I know the LS1 is known for the notorious "tick" but it was different this time, it sounded like there was metal rattling around somewhere in the engine (possibly a bearing????) also after a minute or two it developed a "squeak" idk if its a pully bearing squeaking or what but here is a video for yall to listen.
Also the rattling went away as soon as I was pulling into my neighborhood...
Ideas anyone?
http://www.youtube.com/watch?v=WHFg28UIc9I
Old Feb 11, 2012 | 03:38 PM
RonSSNova's Avatar
Remove the oil filter and carefully cut it apart and look for metal.
Drain the oil and do the same.
It's cheap diagnostics.
It has that dull sound of a rod bearing.
If the filter and oil look good, look elsewhere.
Try removing all the belts and see.
Ron
Old Feb 11, 2012 | 04:02 PM
cranny's Avatar
Yep, sounds like the bottom end going. How many miles on the car?
Old Feb 11, 2012 | 06:20 PM
CHADsterss's Avatar
160xxx
We think it's either a collapsed lifter, collapsed valve spring, or a bent pushrod
Old Feb 15, 2012 | 02:36 PM
CHADsterss's Avatar
Welp found the problem LOL
Old Apr 4, 2012 | 08:17 PM
Cthulu's Avatar
Default ****
**** my car just started making that same noise and I'm 500 miles from home....
So this may be a stupid question..but how driveable is a car with a bent pushrod?
Would I be able to make it home if I kept the RPM's low on the highway?
What kind of damage am I looking at if it gets worse?
Old Apr 4, 2012 | 08:49 PM
redsilv's Avatar
that aint a stock rod is it?
it looks like black powdercoating
Old Apr 4, 2012 | 09:32 PM
3rdCoastPowerSports's Avatar
yeah that looks like a hardened pushrod,,, or you powder coated the stock ones... how do you bend a hardened pushrod just driving home
